1998 Camaro, Engine Build Up
Please don't put a God Speed Turbo kit on your car. Its an eBay kit so it will have terrible quality, fitment issues, etc. If you really want to go Turbo check out the Forced Induction Section and look at the Truck Manifold Stickies at the top of the page.
Your ls1 block might be reusable. Ive torn down two different 98 ls1 engines that had little to no cylinder wear after 106k and 141k miles. The factory rings are easy on the sleeves so if the engine was properly maintained the cylinders may still clean up. As mentioned earlier the 97-98 ls1's had a thinner sleeve so 3.903 is about as far as you can safely hone. A 4" stroke in your ls1 with a specd cam will make 400whp easy.
