building a cheap short stroke motor
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
LQ block 6.0 +.060
LR4 crank/rods (4.8)
+.060 over replacement speed pro lq4 pistons
Clevite bearings
precision machining/balancing/assembly/clearances.
This makes 338ci. I believe it will handle 8000rpm shifts.
I would use 243 heads and ls6 intake.
Of course Jesel rockers. LPE GT11 cam. 10:1 scr
I think this motor would do well in a road race/circuit/autox car.
I would use it in 3rd gen camaro with a t56.
I think it would be very responsive, wind up quick and recover fast out of corners
Likely going to be a custom rod (there goes the budget aspect of this build). Might be less expensive and faster build time to get a shelf stock rod and custom piston!
Are you doing this for a class?
Look for a very light weight car for this kind of engine.
No class, no one could ever say I had any class
I have to go custom. Having a set made for 754.00 and change. They will also balance the rotating assembly and install a reluctor wheel for the same fundage. Sent the crank and pistons out Monday. 6 weeks, I should have it all back.
This project is still uber cheap. Grabbing a 6.0L block from Summit for 800.00 shipped. LS3/L92 heads, the SLP roller rockers I already own, "hot cam" and call this project acquired. Junk 5.3L (200.00) for all the covers and stuff.
GMPP or Edelbrock carb intake with MSD for spark. Should rev well and I found a 72 Camaro that this will go in with the 6 speed manual I have.
This combination or the one NemeSS suggests is going to allow you extra money to build a valve train that can handle the rpm your going to throw at it. Think titanium. Think very expensive.
That being said, here is my experience. You can actually go too long on your rod to stroke ratio to where there is diminishing returns and you've got a sluggish motor on the low end. My problem with doing years of research on long rod motors is off the shelf cams are not going to work for you. There are engine dynamics involved such as increased dwell time at TDC that call for an unusual cam grind and unusual header design. Don't take my word for it. Call the tech support for a few popular cam companies. Tell them what you are proposing and ask what cam grind they suggest. I bet you'll get as many different suggestions and theories.
Here is my suggestion. Sell the pistons you have. They are for a stroker application where the compression height is actually working against you. Then purchase a stock LS2/6.0 forging with a more reasonable compression height (I believe it's 1.341). Now you can purchase off the shelf Eagle H-beams with a 6.300 length (part number CRS6300B3D) for a shade over $500. The final desired piston deck height can be easily found by milling. Check my math but I believe you'll be there with a more reasonable rod to stroke ratio.
Thanks. 3K is expensive for a fully forged shortish stroke motor?
I will probably save the pistons I have and grab something different, as you suggest. Except that I already own the crank, too. Short 3.185 stroke.
3K is pretty good for a forged short block. You still need a good set of heads with at least lightweight LS6 valves or better, lighter titanium valves to spin to 10K. Titanium retainers are going to be mandatory along with some premium valve springs. Custom cam for long rod to stroke ratio might be in order and an oil pan that can control that kind of rotating assembly rpm with a high quality oil pump. I'm not familiar with Summit's machined blocks but blue print machining including torque plate honing, squaring, decking will be necessary if you want this thing to live awhile. Studing the mains and probably the heads would be smart.
