people tell me my cam sucks for my 383 Why???
Old 05-08-2012, 10:59 PM
LSXFEIN's Avatar
Default people tell me my cam sucks for my 383 Why???
hello everyone can someone explain to me why my camshaft sucks for my 383 stroker? i have stock ported heads...they say its too mild but i dont see how? thanks for any advice![IMG][/IMG]
Old 05-08-2012, 11:03 PM
Theblacknightls1's Avatar
The camS lift I'm assuming
Old 05-08-2012, 11:07 PM
06X6spdGTO's Avatar
Valve lift and the Lobe seperation angle could use some attention. Just my .02cents
Old 05-09-2012, 12:38 AM
LSXFEIN's Avatar
Oh ok the cam does seem a lil laggy at low rpm
Old 05-09-2012, 01:15 AM
Blk98Vert's Avatar
That cam seems like a procharger cam, a cam along the lines of a MS4 on a 113 would be a better mild cam for a 383
Old 05-09-2012, 02:04 AM
LSXFEIN's Avatar
Default thanks
Right on man thanks!
Old 05-09-2012, 06:33 AM
Internet Mechanic
BlackScreaminMachine's Avatar
The larger the motor is, the more cam you can have in it without being "cranky". So what was considered extreme on a 346 LS1 such as a T-rex or MS4 may seem tame if you stick it in a 408.
If I was building a N/A 383 the LSA would be in the 109-110 range easy and go from there.
Blower cams will give you a laggy feeling BUT that can be helped with a properly spec'ed TQ converter or if its a 6 speed car, putting 4.30's or a M12 trans.
Old 05-09-2012, 08:36 AM
mark21742's Avatar
You could run a tighter lsa to get the power coming in sooner, and a little more exhaust duration.....lift is up to you.....if you go higher lift you can make more power, but it will be harder on your valvesprings.....with the lift you have now you could run a good set of beehive springs for years and years and not have any wear on them, but once you get over .600" lift you need a heavier set of springs and need to check spring pressure every 10-12k miles, and maybe replace them.
The larger cubes do really eat up duration.....I'm running a 255/263 .624/.624 115lsa in my 408 and it has pretty good street manners, but pulls all the way up to my 8,000 fuel cut.
Old 05-09-2012, 08:54 AM
CamSS96's Avatar
I've been looking for a cam to start me a pile of parts. I have a 96 SS Lt1 any info is much appreciated as I don't know anything about engines, and I don't know anyone who knows anything either. Please and thank you
Old 05-09-2012, 10:07 AM
DONAIMIAN's Avatar
Kinda curious how suggestions are being made when the only thing we know about the motor is that it's a 383...
Old 05-09-2012, 10:16 AM
dodson55's Avatar
lift is a little low lsa needs to be around 112 and i dont like that it is a single pattern cam with that much duration
Old 05-09-2012, 10:48 AM
LSXFEIN's Avatar
yes i hear alot of people say MS4 is the way to go
Old 05-09-2012, 10:54 AM
kinglt-1's Avatar
I hear alot of people say alot of different things...most of its BS. Need to know your full setup, then we can speculate on camshafts. You spec the cam to your displacement and heads, not the other way around!
Old 05-09-2012, 10:56 AM
LSXFEIN's Avatar
yea that around where my fuel cuts out to. Ok so the lsa is what deals with rpm range then? I want get more lift too
kinglt-1's Avatar
I hear alot of people say alot of different things...most of its BS. You need to spec the cam for your displacement/ heads/ compression/ purpose, not the other way around!
Old 05-09-2012, 11:03 AM
LSXFEIN's Avatar
True. its a 383 stroker with 10.5 compression stock ported heads with some "ok" aftermaket springs http://schneidercams.com/6700-16valvespringset.aspx and 7.400 pushrods and aftermarket valves. It has a fastx setup 90mm manifold 90mm tb, Longtube headers 3 1/2 in exhaust all the way back. stock fuel system (Upgrade coming soon) its a 6 Speed, stock gearing in rear, running 275/45/17...
Old 05-09-2012, 11:04 AM
Internet Mechanic
Exactly, compression ratio whether STATIC or DYNAMIC factors in greatly.
LSXFEIN's Avatar
Very true! its a 383 stroker with 10.5 compression stock ported heads with some "ok" aftermaket springs http://schneidercams.com/6700-16valvespringset.aspx and 7.400 pushrods and aftermarket valves. It has a fastx setup 90mm manifold 90mm tb, Longtube headers 3 1/2 in exhaust all the way back. stock fuel system (Upgrade coming soon) its a 6 Speed, stock gearing in rear, running 275/45/17...
Old 05-09-2012, 11:06 AM
LSXFEIN's Avatar
ive also been told a single pattern is old school and no good, and to get a dual pattern, but i dont understand by what they mean with the pattern?
Old 05-09-2012, 11:50 AM
mark21742's Avatar
Single pattern is like a 224/224, 228/228, or this cam, a 240/240...a split, or dual pattern has more exhaust duration like a 220/224, 228/232....a reverse split pattern has more intake duration, like a 228/224.
Quick Reply: people tell me my cam sucks for my 383 Why???
