Looking for input on 243 head options
Old May 18, 2012 | 07:54 AM
chrs1313's Avatar
Originally Posted by Jason 98 TA
The PRC 227 head is the highest flowing current production 3.9" bore cylinder head out there. Its designed as a max effort cylinder head specific for small bore applications!
I am assuming that there is data to back this up correct? If so can you please post, I am sure others along with me are very interested to see this...
Not doubting at all just would love to see the data being an engineer i guess
Also have you ever done a top head comparision for a maxed out setup...mast 225, TFS 225, AFR 230v2, PRC227s
that is impressive that you hit 500rwhp with a ls2 and stock intake...would love to see the build on that too...
thanks
sorry for the partial hyjack OP
Old May 18, 2012 | 11:25 AM
mac62989's Avatar
Im also interested in that, Ill have to check out those heads.
Old May 18, 2012 | 12:11 PM
PREDATOR-Z's Avatar
IMO, comparing just airflow is not the way to choose that one head is better than the other. That is like dyno comparison, mostly good marketing.
Old May 18, 2012 | 12:25 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
http://www.hotrod.com/techarticles/e...t/viewall.html
There's a quick link to an article where an independent test showed flow testing and engine dyno testing on the heavy hitters. The PRC's (237's granted) were bettered in average power only by one head which retails at about $300-400 more than the PRC. I am told there are other independent tests with the PRC 227's and the comparable competitor heads in the works as well
Also, the quickest stock bottom-end LS1 F-body record was set by the PRC 227's and a Magic Stick 4.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old May 18, 2012 | 01:24 PM
mark21742's Avatar
I'll make you the deal of a lifetime Matt......send me a set of your biggest best cathedral port heads snd I'll independently test them for years for you.....and i wont chargr you a dime
Old May 18, 2012 | 01:43 PM
PREDATOR-Z's Avatar
Hmm, I recall us having this discussion before
How much does that car weigh again?
Old May 18, 2012 | 02:08 PM
Just a hair more than the 2nd Quickest stock bottom-end LS1 F-body does, if I recall correctly
__________________
Old May 18, 2012 | 02:13 PM
chrs1313's Avatar
that is great i have seen that article and all heads were fairly close...
your statement said that the PRC227 is the highest flowing head on a 3.90 bore which is very specific so i thought you might have back to back results...
So i am confused the head in the article was a PRC237 and it wasnt on a 3.90 bore to boot? So where is the statement stemming from that you made...
 Michael S. Palmer
Old May 18, 2012 | 02:22 PM
Yea, it was the 237's, TFS 245's, etc that were tested. I made the statement the test with the "medium" heads such as the 227's is in the works.
__________________
Old May 18, 2012 | 02:41 PM
speedtigger's Avatar
Old School Heavy
That was a great article. Oddly enough that article is what inspired me to buy your ported LS6 head. Once I had seen how much power a well ported stock casting could make, I could not pass up the great price.
Old May 18, 2012 | 03:04 PM
FLYNAVY30's Avatar
Well, after much research, and listening to many, many opinions on the subject, I ended up going with the Livernois Stg 3 243s. My thought process was 1. $2000 was the absolute max, which ruled out trick flow and afr, plus there are plenty of guys getting impressive results from CNCd 243s. 2. I drive the car almost daily, so being able to turn the car around over a weekend was a must for me. This ruled out TEA, AI, and a few of the other popular cylinder head specialists who no doubt do phenomenal work, but dont typically keep core heads on hand (I called and asked all of them). 3. The few guys I could find who were running Livernois heads, had nothing but great things to say about them....especially for a street car. None of them were turning heroic dyno numbers, but with similar mods to mine, were making pretty impressive torque around 3000 RPM. 4. Lastly, Rick at Livernois was extremely helpful in answering all of my annoying questions over the course of the last week.
So I placed my order for the heads this morning, hopefully Ill have them in the next week or so and can get some results posted up here in the near future. I just got my big box of parts from Jegs with the gaskets, LS7 lifters, lifter trays, ARP head bolts, ARP bolt hole cleaner tap, Comp trunion upgrade, push rod checker, FAST 36lb/hr injectors, and torque wrench so I think Im all set for the install....hoping Memorial Day Weekend
Old May 18, 2012 | 06:38 PM
  #32
mac62989's Avatar
^In for results..
Old May 19, 2012 | 12:17 AM
  #33
PREDATOR-Z's Avatar
Good choice, I've used their product about 2.5 years ago and they delivered as advertised.
Over the years I've had about 6 pairs (personal) of different vendors and Livernois ranked amongst the better ones. The best i've used in stock casting are the ones I run on my C5 right now. They delivered the best lower rpm torque, however since cams used were sometimes similar but not exactly the same, it is not a direct A>B comparison.
I am not an advocate of huge cams as I mostly drive my setups on the street.
I've even used a set of 317 ported by Bo White and for the $$ they were great. That was on a supercharged 06 C6 LS2 running 7 psi (No meth. allowed where I lived at the time).
The first set I bought (stage 2.5 5.3L) was the worst in many areas (back in 2005)
Old May 19, 2012 | 12:47 PM
  #34
mac62989's Avatar
The stg 3 produce the best low end torque? Your using Livernois on your setup in your sig? edit: Nevermind see your using Cartek 243s..
Old May 19, 2012 | 08:26 PM
  #35
Bo White's Avatar
I try, thanx for letting me give em a shot
Old May 20, 2012 | 02:17 AM
  #36
PREDATOR-Z's Avatar
You're gifted and you went out of your way to help me. You delivered as promised. You work hard and deserve recognition. I hope you are doing well these days.
Old Jun 22, 2012 | 12:28 AM
  #37
Bradlyj8Z28's Avatar
Flynavy, results?
Old Jun 22, 2012 | 06:38 AM
  #38
FLYNAVY30's Avatar
sorry, slow going due schedule at work the past two weeks. Ive got the driver's side head on and torqued...need to measure for push rods this afternoon and get those ordered. I will post results as soon as I have them....hopefully by the second week in July
