Calling all pros need arp torque specs for cylinder heads
Old 05-15-2012, 11:24 PM
LSXFEIN's Avatar
Exclamation Calling all pros need arp torque specs for cylinder heads
[IMG][/IMG]
Old 05-15-2012, 11:33 PM
Turd Gen Guy
1nasty86's Avatar
I always go 40-60-85 on my arp studs on the larger ones and 22 ft lbs on the small ones up top
Old 05-16-2012, 12:07 AM
LSXFEIN's Avatar
Default Awsome
Awsome sir thank you very much!
Old 05-16-2012, 08:43 AM
badazz81z28's Avatar
ARP instructions show 80ftlbs for 7/16" studs / 25 ft lbs for the small ones.
Slowing ramping up the torque is so you dont warp the head.
Old 05-16-2012, 11:28 AM
LSXFEIN's Avatar
Default OOOo
oh ok is that for the studs and the nuts?
Old 05-16-2012, 11:35 AM
Turd Gen Guy
1nasty86's Avatar
says go to 80 ft lbs using arp lube.. i 99% of the time use engine oil so i go to 85ft lbs and the small ones i take to 22 ft lbs.... has worked for me with 4-5 different rebuilds so far
Old 05-16-2012, 09:56 PM
LSXFEIN's Avatar
Default Great
Wow thanks man your awsome what kind of oil do you use?
Old 05-16-2012, 11:00 PM
Turd Gen Guy
1nasty86's Avatar
usually whatever im gonna use in the engine because thats whats laying around... but its usually 5w-30
Old 06-03-2012, 08:17 AM
therabidweasel's Avatar
I'll add to this thread the torque for BOLTS
P/N 134-3609 Gen III/LS (2003 & earlier)
Using ARP Ultra-torque lube, manufacturers sequence, and three equal steps:
M11 = 75ftlb
M8 = 25ftlb
I'm sure its on here in a thousand places, but what's one more?
Quick Reply: Calling all pros need arp torque specs for cylinder heads
