Four Valve Heads Anyone?
Charlie
Okay, I'll take a set...
aaaaaaaaaaakkkkkkkkkkkk!!!!!!!!!
another set of heads i have to wait for the design and results b4 i can by a set...
i been waiting for afr to show there results and was getting down to the wire then i read this.....
so now how can i get the afr heads (if they put 15+hp on the current guys) if there is a chance that these heads will turn around and put down 15+ on THEM !!!!
that being said... i cant wait to see the prototype
1. Stronger Decks
2. 20 HP+
3. Simple Install
4. Price under 3K
Will you please give me some input on the following?
Q1. What is the highest compression ratio you would use?
Q2. Is having pistons cut for valve clearance too much work?
Q3. Will special exhaust headers be too expensive @ $600 (guessing)
Q4. Would you rather just have a good canted valve or twisted hemi head with less cost and complcation?
Thanks again for your input, I look forward to your thoughts!
Best Regards
Jon Schmidt
jonathanschmidt@mail.com
www.motorsportsdesign.com
www.schmidtmotorworks.com
Ok,
1)yes stronger decks
2)20+hp over current ported heads
3)cant really get any simpler than stock, just dont need a 10page install manual ya know.
4)Even 3500 if all else met would still sell, but sure 3k or less is a good goal.
New "?"
1)I would think an average CR of 8.5:1 for boost, and highest of 12:1 for NA/Nitrous. Of course having 2 different chambers like current 66 or 76, with ability to mill solves most of that. There will always be the few that need that 13.25:1 CR or 9:1 etc.
2)I wouldnt say it too much work. There are plenty of ppl here currently doing it with block in car, just to fit a cam! Most boost apps wont need to I dont think, but NA/Nitrous would be another story and most going forged will most likely have a valve relief. But shouldnt be too much work, as long as its known up front unlike some of the recent developments in the LSx community.
3)Headers, thats a bad choice there. Unless absolutely necessary, I would try to keep the factory style/location as much as possible, only if it wasnt feasible. The header industry just came on line this last year, and some of the poor coatings and welding is starting to show its ugly head. As can be seen in some posts in the external section.
4)If you can do a hemi, locating the plug up top centered, I would like that. I am not familiar with benefits of one over the other. Swirling sounds more today tech opposed to Hemi being old school. If they both flowed, and had similar flame propagation, unshrouding etc. then KISS, keep it simple!
Thanks for showing intrest.
Charlie
1. Stronger Decks
2. 20 HP+
3. Simple Install
4. Price under 3K
2.--Yes 15-20+ Hp on current available PORTED heads.
3.--Yes simple install---compatability with current intakes would be nice.
4.--Yes, Under $3,000 if that is feasible.
Q1.--The highest compression is relative to the application; but most heads and cam cars have about 11.0-11.5:1 Compression Ratio.
Q2.--Cutting pistons should not be needed. As stated earlier, two intake vlaves will flow more at .500" than one will flow at .600". Cutting pistons is not needed with current milled heads untill you get to .600" lift or more.
Q3.--Special headers will not be a problem, and if you can get them to us for @$600 that would ROCK!
Q4.--A good flowing hemi head with big valves would be killer. Again, if it does not demand a special intake manifold it would be better.
Sounds like you have great idea here. The 4 valve head would be nice. (Are you talking cam in block with each rocker operating 2 valves ala AERO, or are you talking about a real 4 CAM set-up?) I really like the Hemi idea too. Special Intake Manifolds and Headers will make this very expensive and out of reach for most people, but it sure is cool as **** to think about.
The only really impressive 4 valve V8 engines I've seen were all forced induction.
Here are some issues I am dealing with that I would appriciate your input on.
1. Using the stock exhaust or standard headers on a 4-valve, canted or hemi will probably be nearly impossible. The main reason is that the exhaust face of the head on the 4-valve and hemi heads has to be nearly square to the deck so that means facing 45 degrees down in the car. Also it is moved out about 1/2 inch (at least) Let me know if you can live with buying the special header or if this is a deal breaker.
2. If I do a four valve with a price target in the 3K range, it would have to be a push-rod set-up like the arao someone here mentioned. For a DOHC, I think the cost of the parts and room for all the front of the engine stuff that would have to be moved forward on spacers would be a bigger headache than most people are willing to go for, let me know if I'm wrong about that.
3. Some of you seem interested in the hemi design, at least partly for the spark plug issue. After looking the cars in the dealer today, I can see why, the engine is nearly under the windshield. If I made a hemi, it would be possible to use the same intake and a slight possibilty of the exhaust. A modern hemi would have a twisted intake and exhaust valve similar to the 429 Ford (SCJ) or even better example the Ilmor pushrod Indy engine from about 1994.
If the pushrod twisted hemi would a better fit for cost and practicality reasons, maybe that would be the way to go. Please let me know your thoughts on this type of head as compared to a pushrod 4-valve.
If you can produce a cast aluminum head for under 3 grand, you should consider making a cast manifold for a C5R head with a clone head instead. If someone would cast a intake for a C5R I think more people would use them. The C5R head will accept stock headers and will make a ton more HP than a conventional gen 3 head.
2.--I agree. I was just wanting clarification. The pushrod route with split rockers like AERO will be much easier than a full DOHC swap. Let's see the pushrod version.
3.--I also like the Hemi head idea, but I like the 4-valve idea better. The complex angles for a canted valve hemi head I wonder about. With a 4-valve head it would seem you would be able to have similar power and torque with a lower lift cam, and therefore lighter valve springs. This is a toss up. I would buy either one if I had the $$$$, and they met the previoiulsy noted requirements-----stronger thicker deck, more power than current ported heads, etc. I'd like to see a larger chamber for forced induction cars also----maybe equilavent to a 9.0:1 CR.
Charlie
Are they much different than a 6.0L #317 casting?
I see pairs of C5 heads selling on Ebay for $150, they don't seem to be very valuable. maybe the R is a big difference?
schmidtmotorworks
Yes the C5R heads are way different than the 6.0L heads. The C5R heads are a special casting that GM made for the Corvette Race Car. Huge intake and exhaust ports, tiny combustion chambers (13:1+ compression ratio), and require a custom intake.
I still say that a well designed 4 valve head could out flow the current ported LS1/6 heads and maybe equal an as-cast C5R head with better charge velocity (TORQUE) from the smaller port volume.
Just my thoughts gang.
These are the same heads that propelled the C5R Corvettes to a LeMans 24 hour win. The are for maximum effort Gen 3 racing engines, which should incorporate the use of a Gen 3 racing block P/N 12480030, also. A special manifold must be fabricated to use this head. The cylinder heads include the following features:
The basic height, width and attachment faces are in stock location to dowel and deck position. All dimensions and fasteners are metric.
The basic valve angle was revised from 15 to 11 degrees to produce a smaller chamber . The valve angle also provides more space for aftermarket shaft mounted rocker arms.
The rocker cover hold down bosses are incorporated into the rocker arm plateau for the 4-bolt center hold down type cover (1999 model year).
The chamber volume for the P/N 12480005 head is 38cc with flat faced valves of. 75mm inlet and 1.5mm exhaust margins.
The P/N 12480090 provides additional material for CNC porting and chamber shaping and starts at a volume of less than 30cc's.
The inlet port roof and floor is raised and the attachment pattern is designed for a Kinsler type fuel injection manifold. Inlet port is 57.15 x 36.58mm / 55.957mm dia. precision finished.
The cylinder head is machined for larger diameter springs (41.5mm or 1.63" dia. machined pocket).
The exhaust flange is identical with the production part.
The exhaust port is stock size.
The head is machined for a 12.712 / 12.688mm dia. valve guide bore.
Rocker cover oil rail seal is a reverse tapered groove for a 3.2mm dia. (.125") free length "O" Ring.
