Four Valve Heads Anyone?
Old Apr 6, 2004 | 06:23 PM
  #61
Cheatin' Chad's Avatar
Originally Posted by Reckless
I would listen to what Kurt (427) has to say, he builds these engines for a living. Not to mention he will be my boss in a few weeks
Cast a C5R head with or without valves and come up with a cast intake to fit and you will have a winner. The smaller bore guys can stay with stock stuff if they want to.
Wouldn't it better for most people to have a C5R type head that will work well with the stock size bore? Would sizing them down to fit the stock bore destroy their ability to flow as well as they currently do? I'd imagine the valves and ports where moved around to make the numbers they do.
If you have a 4in bore you have the option of going to the C5R heads.Although I'd imagine they are pretty pricey.
Old Apr 6, 2004 | 09:05 PM
  #62
1CAMWNDR's Avatar
Actually, if anyone is considering C5R heads, they already likely have a 4"+ bore. A C5R head with smaller vlaves to fit the 3.9" bore would lower their advantage against Stage III 2.08"/1.60" heads.
Yes C5R heads are expensive------$1,000-$1,300 each depending on prep. I think the CNC complete heads are $2,300 each, but I think they were discontinued.
Check Scoggin Dickey in the sponsors listing----->
Old Apr 6, 2004 | 09:21 PM
  #63
Silver6sp's Avatar
personally i wouldnt bother, just from the fact of chevy building engines with two valves and 16pushrods going well over 400 horse, what kind of gains could 4valves per cyl do. im a ford tech(with a 00z28) i look at how the cobras are four valves per cyl and make less power than a ls1, maybe its just ford buuilding them i dont know, im not trying to biss ford right now but thats the way i look at it, anyway if you do build these heads good luck and let us know the power gains
Old Apr 7, 2004 | 09:20 AM
  #64
1CAMWNDR's Avatar
Cool
Also, I think the smaller 3.9" bore is a good reason to go 4 valve.......2 smaller valves would flow as much if not more than a single big vlave and not be as affected by shrouding or the hitting the cylinder wall .
Silver6sp, I know where you are coming from. I don't know if the Ford motors have poor ports, the small bore, or what the reason is that they don't make more power than they do . I think the ports themselves do not flow nearly as much as an LSx head. If schmidtworks can design a 4 valve head with a port like the LSx already has; I think he will have a winner .
Schmidtworks----would the 4 valve head also have a centrally located sparkplug? I would think that you could still have the sparkplug and boot come through the top of the cylinder head making plug swaps easier . I know this was an idea with the hemi-style head, just wondering if the same would be done with a 4 valve design.
Old Apr 7, 2004 | 09:30 AM
  #65
CHRISPY's Avatar
400 horse? Try 600 horse (flywheel)
Old Apr 7, 2004 | 11:35 AM
  #66
Another_User's Avatar
I think you will find that making these heads will be a waste of money and a futile effort. Especially if by some freakish chance the new 24-valve heads will bolt on to an LS1. Then you will quickly find yourself broke. I have a wonderful idea though...for anybody that would like to do it.
How about a cam install tool, just like the JPR rods, except made out of ABS plastic. That should make them incredibly cheap to make, just as effective at keeping the lifters up, and guarantee that you will not chip or scratch any of the metal parts inside your engine. I particularly like the cheap part because then the savings can be passed on to us.
Old Apr 11, 2004 | 04:32 PM
  #67
1CAMWNDR's Avatar
Any news Jonathan? I'd like to know what the latest is .
Old Apr 11, 2004 | 10:25 PM
  #68
MadMan-'78's Avatar
Post sounds good....
This is just a thought, but could you not use a few design aspects of the Lotus-designed LT5 DOHC heads? You might also look at the Northstar DOHC V8s. These things definately need to be able to handle gobs of boost and/or nitrous. Thick decks are a must. For the issue of keeping low-end torque, make the ports flow well as-cast, but leave the walls thick enough for porting for the top-end junkies who don't mind losing the low-end. These heads would also produce a great wow factor when you pop the hood. The blue oval guys with their whining snakes won't know what hit 'em!!!! Good luck.
-ThaBant
'78 Camaro w/ LS1 & 6sp
Old Apr 12, 2004 | 10:42 AM
  #69
PacerX's Avatar
My $.02:
A DOHC head is going to be a mess to package.
A hemi head is going to be a mess to package and need all kinds of nonsense (coil relocation, intake manifold, exhaust manifold, etc...).
How's about a better C5R head and an intake to match?
Word of advice:
Rumors flying around the LS2 are saying that the intake has been revised to match the C5R layout, which will kill dead any of the aftermarket intakes. If that head is as good as it looks to be AND increases the headroom for the intake relative to max power, AND bolts up to LS1's, there is going to be hell to pay in the aftermarket.
Every intake, ported head, AFR head and a host of other parts will become obsolete overnight.
Find out what GM is doing. Holley didn't, came up with a marginal design, and the LS6 intake wiped out their market.
Old Apr 12, 2004 | 09:33 PM
  #70
1CAMWNDR's Avatar
Originally Posted by PacerX
My $.02:
Word of advice:
That is pretty good advice. What is different about the C5R layout? The LS2 intake will not have large enough ports to bolt to C5R heads will it? I think a 4 valve pushrod head that bolts to the LS2 intake might be a winner.
Old Apr 12, 2004 | 09:44 PM
  #71
427's Avatar
427
The C5R head is a race type head. There is a picture of one in this thread.
The LS2 will bolt on the same port as a LS1. I put one on a 346 road race engine that made 523 hp @ 6900 at the flywheel, it picked up to 540 hp still @ 6900. The LS2 has a fly by wire 90mm throttlebody with a 4 bolt pattern. I think the 90mm throttlebody was where most of the gains came from as they are all above 5000 rpm.
Kurt
Old Apr 12, 2004 | 10:16 PM
  #72
66ImpalaLT1's Avatar
Will the LS2 throttle body be electrically compatible with current C5's?
Sorry to take this thread off track.
Old Apr 12, 2004 | 10:53 PM
  #73
GPowrie's Avatar
I like the idea of the C5R style head, but I would like to see it work on a smaller bore motor. I know I would personaly rather have a cylinder head capable of flowing 360+ cfm, and not have to spend all the money for a big bore block. It would allow us to make much higher power levels and not have to invest as much money. I know the Yates head for a SBF on a 352 cubic inch motor make a lot of power, why couldin't we do somthing similar on a LSx based motor with the larger bore.
Old Apr 13, 2004 | 06:49 AM
  #74
427's Avatar
427
The plug is different. I am going to find out if the 90 can be wired in, but it does not look good.
Kurt
Old Apr 13, 2004 | 07:31 AM
  #75
Reckless's Avatar
Super Moderator
Kurt always gets the fun stuff to play with That LS2 manifold is pretty beefy looking. Saw it Saturday when I stopped by.
If it were my investment it would be easy, C5R cast head with thick decks and a cast two piece intake to fit the heads. Two piece would allow easy porting and polishing. Make the intake compatible with current fuel rails, etc.
Old Apr 13, 2004 | 04:26 PM
  #76
XLR8NSS's Avatar
Adkoonerstrator
Why don't we all just wait for the AFR 225s to come out and see how much flow can be pulled outta them. Maybe they got enough meat to carve a C5R type port in them??
Old Apr 13, 2004 | 08:08 PM
  #77
PacerX's Avatar
Because AFR is proposing a rape-job $2600 for their 205 head that can only handle .550 lift without an added cost spring upgrade.
Old Apr 13, 2004 | 10:41 PM
  #78
XLR8NSS's Avatar
Adkoonerstrator
I was talking about the 225s and what MIGHT be possible. I don't think AFR is producing as many LS based heads as GM did so that might have to something to do with the cost.
Old Apr 13, 2004 | 10:42 PM
  #79
verbs's Avatar
Agreed, which is exactly why I went with a hand finished to competition level Judson Massengale LS6 head from TEA shrunk down to a stock bore. I was really hoping AFR's heads would come through, but with the current heads on the market getting better and better (and the prices being very reasonable), I don't see how AFR will compete. TEA's massengale program is cranking out ls6 heads making 340-350cfm up top these days on big bore motors, so AFR is going to have to come out with not only comparable flow, but killer velocity to take over.
Old Apr 14, 2004 | 12:57 AM
  #80
bodhi's Avatar
As many have stated, why fix what's not broken? We are getting killer #'s out of the stock heads. It's the intake that is slowing us down. Why not do the R&D on some killer new intake designs? MAybe something along the lines of a mass produced sheetmetal intake with a large plenum and short runners.
A Victor style FI intake for the LSx's would be awesome.
The stock heads are good adn they are working, but there is more potential there, AFR is working it out. Maybe you could make a street head affordable- (relatively) small runners, high velocity for us stock cube guys...
