Four Valve Heads Anyone?
I am considering going into production of 4 valve heads for the LS1.
Can any of you tell me your opinion of the potential popularity of 4 valve heads for this engine?
The current plan is to use a design similar to the Quad 4.
Any ideas, opionions, suggestions appriciated.
Best Regards
Jonathan Schmidt
SchmidtMotorWorks
jonathanschmidt@mail.com
i think it would be a big step forward. i dont know much but from what i have heard a 4 valve head will be more efficient than a 2 with big valves.
Arao Engineering currently makes 32-valve heads for older small blocks, and they have made impressive gains (203 hp over stock iron heads, and 159 hp more than "high end" aluminum heads). They are also (per the website) good for over 9,000 rpm revs with no exotic valve train parts or "freakish valve spring loadings".
http://www.araoengineering.com/Chevy/chevysmb.htm
They aren't cheap however (somewhere north of $5k if I remember right). If there was an affordable LS1 varient that could produce gains like that, I'm sure people would be lining up!
Bruce
But, the advantages of a 4 valve head would be so incredibly great. As long as you made the port small to keep the torque around, they would be the best thing that could happen to these engines, IMO.
As for basing on a Quad for head, those things are well known and hated for their tendancy to blow head gaskets. My wife has a 95 Granda Am and it blew one. That tendancy if present in your new 4-valve will doom it.
If AFR can get $2500 for their CNC'd LS1 head I would think you could get a similar amount. You'll have to beat every ported 2-valve head on the market with worth while gans everywhere. I think you'll have to have your head turn key to do all of that for $3,200 max and about $2,500 if you really want to sell a lot of them. Folks will have to switch to much smaller cams than what's popular now. The will be a hard mind set to break for some folks.
As for the big gains with 4-valve heads, a 2-valve can make the ~same peak numbers if optimised but the 2-valve will make less everywhere else.
Do all that, keep the price livable, and you got it.
Best Regards
Jonathan Schmidt
SchmidtMotorWorks
Jon,
I think every previous post was excellent and informative.
If you consider all of the previous posts, especially about the head thickness for boosted applications, maintaining velocity for NA applications and pricing you would make a killing.
I have no doubts that this head would flow great numbers v.s. the 2 valve set-up.
vaporware
