Is dyno tuning needed...?
Old Mar 30, 2004 | 10:11 AM
OttawaLS1's Avatar
Default Is dyno tuning needed...?
There is no dyno tuning shop anywhere around where I live... closest would be ARE about 4hrs away... so just wondering if it's possible to do a cam and intake and headers/ory without tuning, or to use my Predator to tune these?
What about doing a heads/cam package? Tuning needed there I'd assume? Also, if doing heads, would injectors and fuel pump need to be done also or stock ones ok?
Old Mar 30, 2004 | 10:14 AM
DenzSS's Avatar
Where are you located? There is a shop in Silver Lake, WI that does very good LS1edit tuning.
Old Mar 30, 2004 | 10:26 AM
OttawaLS1's Avatar
Ottawa, ON Canada
Old Mar 30, 2004 | 10:44 AM
DenzSS's Avatar
Gee, I should have looked at your username
I'll talk to some of the guys near the border and see if they know of anyone in your area.
Old Mar 30, 2004 | 10:46 AM
DenzSS's Avatar
Tuning is needed for most head/cam packages. Your stock injectors and fuel pump will be just fine.
Old Mar 30, 2004 | 11:02 AM
OttawaLS1's Avatar
Awesome! Thanks I was thinking about putting on a used blower, and know I'd need injectors and pump for those, but wasn't sure on H/C setup.
Old Mar 30, 2004 | 11:09 AM
01_SuperSlow's Avatar
You could also look into mail order tuning.
Old Mar 30, 2004 | 11:13 AM
DenzSS's Avatar
Mail order tuning just doesn't work worth a damn. You can get it close sometimes, but who knows if you're going to run into trouble. I've ran into cars that had the exact same mods but reacted in a bizarre way. The only way to correct those is to thrash on it and figure out the issue. You just can't do that through the mail.
Old Mar 30, 2004 | 02:20 PM
OttawaLS1's Avatar
I'd think a custom tune for my Predator would work much better then a mail order tune... and that way I get to drive my car in the meantime!
