Valve train noise video (moved from external genIII)
more questions.
So I put it all back together with the 7.350's, I had just used the stock length approx 7.38. After it started the lifters were noisier then they were before.
My question is regarding measuring. When I use my comp cam tool im at 7.625 plus my preload approx .088 with 7.350
It takes 1.25 turns to from zero lash to torgue. Using the other method of turns .047 per turn gives me .059 and someone else says to subtract 1/3 turn because of the 1/3 of no movement to torque. Then I have .043
Where am I going wrong.
more questions.
update,
As soon as the lifters pumped up they stopped the clacking. There is still some noise inside the cab and down by the long tubes where they go past the block. I did take a stethoscope to the block. All noises some normal top and bottom, the low end has a nice whirling sound, top end sounds like a moving valve train, not abusive noises. The loudest racket is coming from the injectors, damn there loud. I wonder if the injector noise can travel down and amplify through the headers. Still runs like its **** don't stink so I am officially done chasing the phantom valve train noise. I figure this thread will be a good learning tool for newbies.
Another update. So my valvetrain noise has gotten worse. I just rolled about 4,000 miles and cranked it up the other day. It sat while I did a vette brake swap and the lifters sounded worse. I warmed it up and drove it down the street. At approx 4000 rpm the "normal" chatter went to quiet and back to chatter a few times. I let the rpms settle and put her back in the garage. Upon inspecting the oil it appears there is some fine metal particles in the oil, not much at all but enought that when I wipe the dipstick on a towel I see a little glimmer where the specs are. Plans are to pull the heads and inspect the lifters and cam. If nothing is found the block will get pulled and mains inspected. While I am in there new springs and a PatG cam will be added. No point in doing all that work with out an upgrade. The whole time oil pressure was approx 55 at idel and 65ish under load
newest video, good headphones and speakers recommended to hear the real noises down low.
![](http://i1143.photobucket.com/albums/n633/jamcdonald/th_video-2012-09-26-16-36-26.jpg)
Pulled my intake and valley cover tonight. The front and rear visible lobes look great. For the 4000 miles there was not much oil in the intake at all. Where to go from here. I will put it up high on jack stand tomorrow and look for exhaust leaks. When I notched the crossmember the engine and trans did flex up and down a few times. I think I am still going to swap in new lifters and remeasure the pushrod length. I can also measure the head height to see if they were milled and maybe have some shaved off.
input?
![](http://i1143.photobucket.com/albums/n633/jamcdonald/2012-10-03182019.jpg)
![](http://i1143.photobucket.com/albums/n633/jamcdonald/2012-10-03182013.jpg)
![](http://i1143.photobucket.com/albums/n633/jamcdonald/2012-10-03182008.jpg)
![](http://i1143.photobucket.com/albums/n633/jamcdonald/2012-10-03182002.jpg)
![](http://i1143.photobucket.com/albums/n633/jamcdonald/2012-10-03181957.jpg)
![](http://i1143.photobucket.com/albums/n633/jamcdonald/2012-10-03181950.jpg)
![](http://i1143.photobucket.com/albums/n633/jamcdonald/2012-10-03180619.jpg)
![](http://i1143.photobucket.com/albums/n633/jamcdonald/2012-10-03180614.jpg)
![](http://i1143.photobucket.com/albums/n633/jamcdonald/2012-10-03180609.jpg)
![](http://i1143.photobucket.com/albums/n633/jamcdonald/2012-10-03180604.jpg)
![](http://i1143.photobucket.com/albums/n633/jamcdonald/2012-10-03180559.jpg)
input?
![](http://i1143.photobucket.com/albums/n633/jamcdonald/2012-10-03180521.jpg)
thanks for the input. I was following your thread on lifters. Debating what I should use this go around. Might chance the LS7's again, not sure. I will use the comp trunion upgrade. I used a stethiscope and I can not pin point the ticking to a certain cylinder.
