max compression to run on 93
Old Jun 25, 2012 | 11:04 AM
SStressin's Avatar
Default max compression to run on 93
building my max effort 383 right now and i found out my heads have 62cc chambers. so that would put my compression to 11.528.. is that to much to run on 93?
Old Jun 25, 2012 | 11:08 AM
crazyelf's Avatar
You should be fine with a good tune. Im at about 11.2-11.3 on 91
Old Jun 25, 2012 | 11:32 AM
groundczero's Avatar
Should not be a problem I am at 11.8 on 93.
Old Jun 25, 2012 | 11:48 AM
mark21742's Avatar
What are your can specs, mainly the intake valve closing point? The thing you have to look at is dcr and cranking psi.
In my 408 I'm running 12.5:1 static compression, but my can drops dcr down to pump gas friendly 8.22:1
From all I've found in most cases 8.5:1 dcr and 200psi is about max for 92-93 octane
Old Jun 25, 2012 | 11:50 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
And altitude, and exhaust events, exhaust componentry, etc. DCR is a fun tool and useful, but it is by no means the end-all-be-all of pump gas friendliness calculations.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jun 25, 2012 | 12:00 PM
mark21742's Avatar
Your definately right Matt, but would give a better idea than just the scr number
Old Jun 25, 2012 | 12:21 PM
SStressin's Avatar
cam specs is a eps 240/256 .647/.647 111lsa
Old Jun 25, 2012 | 12:26 PM
Ellesone's Avatar
should be fine
Old Jun 25, 2012 | 12:35 PM
SStressin's Avatar
alright thanks guys! every once in a while i will be throwing in 100 octane
Old Jun 29, 2012 | 09:33 AM
Camaro Junky's Avatar
That gave me a good laugh!
Thanks for the thread; I am in the process of making my LS1 a 383 as well. I will be doing a TSP 383 kit, -3cc pistons and either 64 cc or 63 cc LS6 heads from TSP.
I called Wiseco and I will be between 11.4 - 11.7 on compression, I just need to talk to Matt on what cam would be best.
Old Jun 29, 2012 | 10:13 AM
KRAZY K 2000 TA's Avatar
i am 12.1:1 and running 93
Old Jul 1, 2012 | 02:59 PM
Mighty Whitey's Avatar
It's all in the tune
Old Jul 1, 2012 | 04:55 PM
LS1 Racing's Avatar
So true. I'm at 10.9:1 on shitty 91 octane, ethanol-infested California gas, but Jim @ CalSpeed set me up with a dead-nuts tune, so I'm having no issues.
