Noise from timing chain area
Old Jun 26, 2012 | 07:09 PM
cory32690's Avatar
Default Noise from timing chain area
01 ls1 167k miles past few day been hearing a clicking noise it don't sound like a spun bearing if it's a lifter it's either over pistons 1 or 2 but it sounds like it's coming from more the front of the motor like on the timing chain area
It does have stock chain in it I'm prolly gonna check rockers and pushrods first then pull the cover to check chain
Any other suggestions would be appreciated
Old Jun 27, 2012 | 04:08 AM
vettenuts's Avatar
Sounds like you are planning the right approach, only suggestion I would have is not to drive it. If the chain is in fact the issue and it breaks, you will have much bigger problems on your hands.
Old Jun 27, 2012 | 06:48 AM
cory32690's Avatar
Yea I no..hope it's just a pushrod bent but I don't think that's the issue it almost sounds like it could be coming from the pulleyon theater pump
Old Jun 27, 2012 | 07:34 PM
cory32690's Avatar
I listened to it today on my lunch it sounds more like power steering pump and I can fill alot of vibration from it when I put my hand on it felt valve cover and intake couldn't fill anything out of the norm but that power steering pump fills rough
Old Jun 27, 2012 | 07:56 PM
S10xGN's Avatar
Pull the belt, that should tell you whether or not it's something in the FEAD.
Old Jun 27, 2012 | 08:04 PM
cory32690's Avatar
Yea I'm gonna do that tomorrow
Old Jun 27, 2012 | 08:05 PM
cory32690's Avatar
Appreciate the advice
Old Jun 28, 2012 | 08:38 AM
Jadedbird's Avatar
Ever figure out what the problem was? My buddy's formula has some noise coming from that area too.
