Ls6 cam vs hot cam ?
http://www.ws6project.com/user_stor/catalog/camshafts/
The Comp Cams #54-416-11 would be a nice choice.
http://www.ws6project.com/user_stor/...e-rpm-220-224/
You could even go with a custom grind for $360 shipped.
http://speed-eng.com/store/custom-gr...ft-p-8416.html
Sharper ramp rates need higher spring pressures and that is what one should look at while deciding which springs to choose.
So PREDATOR-Z, what are the ramp rates of the lobes used on the GM Hot-Cam, and/or how do they compare to the Comp Xtreme RPM lobes ?
