Best Intake Manifold and Throttle Body for LS1 Upgrade
If some day you will need or want the fast intake because you plan on doing heads and cam later down the road I personally would just spend the money once and get the 102....you can't over throttle body fuel injection like you can over carb a carbbed motor.....hell of you wanted to run twin 102 mm throttle bodies on a stock motor you could, and see no losses.
