Bearing questions
a line hone is done by cutting the caps. A line bore is simply boring the housing out to a larger, diameter to fix major problems.
if the bore is too out of round, so much will have to be removed from the caps to make it round again, it will change the crank centerline too much, causing other problems.
more often than not...
but there are engines out there that will be bored for different reasons. or you will see it in cracked cap rods such as LS rods.
