N/A build hows it look so far
random tech CAI
FAST 102 intake with 102 TB
texas speed stage 2.5 ls6 heads with 64cc chambers, 2.02 intake 1.57 exhaust
texas speed 228/228 .588 .588 112 LSA
GM ls7 lifters
PAC .650 lift beehive valve springs
7.4 chromemoly rods
yella terra 1.7 rockers
melling high volume pump
factory crank
ls2 timing chain
edlebrock ported water pump
ATI underdrive pulley
1 7/8 long tube headers
what i havent figured out is the pistons. knowing little about them i dont want to choose incorrectly and have piston to valve problems. i know little of the dished vs dome vs flat and cc's. so considering the above build is decent what piston type and cc would yall recommend for his motor? and im concerned the texas speed ls6 heads wont provide a decent power boost over stock or am i incorrect? also would stock lb injectors be good for this build or something bigger like 32lb be better off? thanks for any help
will be the auto 4l60e tranny, might throw in a 2800 stall or something as well.
far as stall goes ill probably bump it up to a 3000 so he can get the full benefit of the cam choice instead of having an a4 car that will bog out.
