anyone running high then stock compression which heads and cam?
anyone running higher then stock compression ratio? if so what heads are you using stock heads? ported? and some dyno numbers you got?
LS1TECH & Trucks Sponsor
Lots of people run higher then stock compression. Almost every aftermarket set of heads and cam meant for N/A hp will raise compression. It is a great way to gain power all the way across the board. You can run up to about 11.5:1 static compression on pump gas with these motors. Giving dyno numbers would be pretty tough because of the broad spectrum of heads and cam packages available. If you could give us a better idea of what you are looking for it might be easier to find some results.
