What is the lowest cc/ highest compression that can run on pump gas?
#41
I think the main reason some don't is that they don't want to fly cut their pistons or just want to slide a camshaft in without having to do a lot of other work.
I do think though that if you're going to be utilizing an aftermarket set of heads and the heads are going to come off anyways that it's a no brainer to get in there and fly cut the pistons slightly to have the benefits of higher compression!
