Achieving 22ft lbs with 140* turn on rocker bolt
Old 08-11-2012, 09:23 PM
82cecil's Avatar
Default Achieving 22ft lbs with 140* turn on rocker bolt
Crank at TDC
stock 317 head w/ upgraded springs
.051 MLS gasket
EPS 226/234 cam w/ 7.425 push rod, new LS-7 lifters
set rocker to touch valve tip without play then begin to measure how far it takes to reach 22ft lb.
not sure I even have a problem, but most threads/posts I ve searched need more than just under 1/2 turn to get the 22ft lb torque required.
Is there a problem?
thanks
Old 08-11-2012, 09:44 PM
Cody Strife's Avatar
I was thinking anywhere between 1 turn to 1 1/2 turns from zero lash to 22 ft lbs of torque was fine.
I prefer pushrod measuring tool myself.
Old 08-11-2012, 09:54 PM
Way2Fast's Avatar
Every 1/2 turn past zero lash is about .025 of lifter preload. Sounds like your pushrod is too long.
Old 08-11-2012, 11:01 PM
82cecil's Avatar
what a person calls zero lash can make a big difference, according to how much play is zero to me vs another, or how much force is used to before the push rod no long rotates.
if I back the bolt out to where the rocker is touching with out "free play", (rocker bolt all the way down but not snug) I can get about 1 1/2 to almost 2 turns to 22ft lbs.
Using the method in the 6.0 manual, I noticed in this effort is that the no.1 intake lifter does not compress as easy as the no.1 exhaust. No. 3 intake is the same as no.1. this concerns me also.
Old 08-12-2012, 06:28 AM
vettenuts's Avatar
Actually, until the rocker bottoms and there is no additional preload applied, each turn is more like 0.038" of preload.
Old 08-12-2012, 01:53 PM
3rdCoastPowerSports's Avatar
I have found the counting turns method to be inaccurate. use an adjustable push rod and feeler gauges to find your zero lash measurement. Then simply add your desired amount of preload and order up the closest size pushrods.
Old 08-12-2012, 02:06 PM
badazz81z28's Avatar
Originally Posted by 82cecil
Crank at TDC
.051 MLS gasket
Is there a problem?
thanks
Hmmm..Most threads I see says to measure for pushrods.
Thats 1/4" this...1/4 that....is just a crap shoot!. Get the tool, measure.
Old 08-12-2012, 02:09 PM
msydow's Avatar
i have only had to measure for pushrods twice and i bought the tool the first time. most vendors can have you the right pushrods in two days anyways.
Old 08-12-2012, 02:26 PM
soundengineer's Avatar
Rocker Bolts have a 1.25 pitch
which means 1 full turn = 0.0492 preload
Ideal preload is actually somewhere between .020 and .040
so you are at roughly .020
which is fine.....
if you are worried about it, then you can buy a shorter pushrod
this is also assuming you are at a point on the cam where the valve would be closed
Old 08-12-2012, 02:28 PM
which is fine.....
I'm pretty certain GM spec for LS7 lifter is more than that.
.050-.080"....Some say .100"
Old 08-12-2012, 02:31 PM
for the stock cam.....yes
aftermarket cam, .020 to .040
Old 08-12-2012, 02:34 PM
also, the base circle on the EPS cam doesnt have enough difference from the stock cam journal to warrant a change in pushrod length...
a 7.400 pushrod would give you that extra preload you were looking for
7.400 pushrod would put you at .045 preload
Whats the difference?
Old 08-12-2012, 02:35 PM
can you back this up with any publications (cite)?
Old 08-12-2012, 02:42 PM
materials its made of, shape of the lobe
you can cause a lifter to basically collapse partially because of the aggressive lobes, which means you need extra travel to allow for that lobe and the new faster rate of travel...
put in a good lifter, and you dont have to worry about that as much
from a few of the cam grinders....optimum around .030
the ranges they say to be within that are still ok..
Cam Motion says .020~.060
Comp Cams says .020~.070
Lunati says .020~.060
most pro level engine builder will tell you .020~.040
they say this for both stability and cam lobe life
Old 08-12-2012, 06:22 PM
My Comp Cam (TSP) instructions do not mention anything about lifter pre-load. I would assume it has to do with the lifter type...I don't know...any else want to chime in on this one?
Old 08-12-2012, 06:39 PM
http://www.compcams.com/v002/Pages/4...icVsMechanical
Says .020~.070 for hydraulic
Also says 1/4 to 3/4 turn
Old 08-12-2012, 06:53 PM
BKsNHRA's Avatar
I use the eps 226-230 cam. 7.4 pr where to short. Noisy as hell. 7.425 made it quiet. This is on stock lifters. I gettin ready to change lifters to ls7 because one of my stock ones failed. I don't know what the preload would be for a ls7 lifter because their not in yet.
Old 08-12-2012, 06:59 PM
like I said previous....020 preload is just fine....and as you see.. your valvetrain is less noisy with the lesser amount of preload
Posted from LS1Tech.com App for Android
Old 08-12-2012, 07:00 PM
Darkman's Avatar
The 1/4 to 3/4 turn referred to is for the adjustment screw on adjustable rockers and not for the rocker bolt for non-adjustable rockers.
Quick Reply: Achieving 22ft lbs with 140* turn on rocker bolt
