replace ls2 rod
Old Aug 23, 2012 | 07:44 PM
velox65's Avatar
Default replace ls2 rod
I just ordered a ls2 setup of rods and pistons, atleast one needs replaced. However these look offset, so do i need a rod of the same side (number 2 even side) or can I just use any ls2 rod?
Old Aug 23, 2012 | 10:16 PM
3rdCoastPowerSports's Avatar
I do not understand your question can you try to re phrase it so I and others can try to help you. do you have pics?
Old Aug 23, 2012 | 10:40 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
All 8 stock connecting rods are the same, even go in the same exact orientation. Basically the connecting rod bearing tang is installed facing the drivers side of the engine on both banks.
Now the piston pin bore in the pistons themselves are machined offset. Again, all 8 factory pistons are the same due to lack of valve reliefs, but as long as the piston dot (for front) is aligned to the front of the engine, there will be no issues.
So in a stock LS1, LS2, etc: All 8 new OEM pistons and rod assemblies can be swapped around in any cylinder, they will all interchange. Bearing tangs to the drivers side, piston marks to the front, easy references.
Old Aug 24, 2012 | 06:28 AM
velox65's Avatar
Yea sorry I didn't make that clear, my issue is with my rods. I'll simplify my question.
If I have to replace a rod, does it need to a rod from the same side.like a gen 1 sbc where the oil holes for the cam are directional. Or can I just buy a rod and go. If this isn't.ear I'll have to get pics lol
Old Aug 24, 2012 | 09:34 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
No, GM made only one part number for the rods in any engine. There is not a driver's side rod and passenger side rod. Same goes for the aftermarket rods.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Aug 24, 2012 | 05:00 PM
velox65's Avatar
Excellent thanks
Old Aug 24, 2012 | 07:06 PM
chrisfrost's Avatar
To Joseph , I was going to send You a pm so as to not rape this thread ,,,,,,,so I guess I'll rape anyway . I have a question regarding what You said about the rod bearings . Both banks You install the bearing tang towards the drivers side ? Thank You
Old Aug 25, 2012 | 06:29 AM
bww3588's Avatar
Yes. Rod orientation is the same for both banks.
