Is it worth it to have my 243 heads cnc ported?
Ive seen his cam only el torro runs. They are badass! But im very interested in this 490hp setup on 243 heads..
my buddy anthony's car...basically blueprinted by rob and me, with an EPS cam...I would have picked one slightly bigger to get that 500RWHP lol but I am a track rat and this is a street car... ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Look at how flat the hp curve is up top...ls3 valves and easy eps lopes
Could seriously pull this motor to 8K with some rod bolts and alumin intake...![Angel](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_angel.gif)
https://ls1tech.com/forums/dynamomet...m-numbers.html
You and only you can tell this.
Ask yourself, is $1000 worth the 30rwhp gain you will be getting?
The problem with "is it worth it" questions is that can vary, some people will think it's laughable to spend a grand and only get 30hp. To some people, a grand spent to gain 30hp is a helluva deal.
I think with a well ported/milled set of 243s he may see more than 30RWHP...
I'm interested on the gains that can be had moving to a lightweight LS3 valve as well. I recently aquired a set of stage 2.5 TEA 243's with the big 2.055 intake and 1.575 exhaust valves. I"m pretty sure they're a stainless valve right now. Would it be worth it to move to a turned down LS3 valve? If so, why?
#37
