59cc head too much??
Check on one of the calculators like wallaceracingcalculators to see what your dynamic compression comes out to....you might also be able to retard your can a few degrees to get the intake valve to close a little later...that will drop your dynamic compression down too....for instance on my 408 I'm running full timing on 93/92 pump gas with 12.5:1 scr, but because of the size of my can motor only sees 8.22:1 dcr
You want an absolute max 9.0:1 dcr for 93 octane....and to be safe is shoot for just at or under 8.5:1dcr
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
If so they're still on my ls1 and have been running great but i want to go full effort camshaft.
Trying to see how big i can go if these are them...ms4 maybe?
That said, those are a set of ported 243 heads right? Texas Speed might be able to tell you if it will have acceptable PTV because all 243 heads milled down to 59cc will have similar PTV. However I'm guessing an MS4 will require flycutting a fair bit.
