LS1 383 Build
The fast setup being that its close to 1k brand new for the 102/102 setup and it will only yield you maybe 10-15whp ON THE upper half of the RPM range (useless for what you want. again like you said you are mostly concerned about mid range). The ls6 breathes just fine till 6500ish, people go with fast setups because the LS6 doesn't work for well for setups reving past 6500ish.
With the money you spent going fast you coud've found some prc 2.5 5.3 truck heads or find some used 243s for $300-400 and send them out to get ported by AI, TEA or other well known porters or **** even send out your 241s to AI or TEA etc..
Like i previously asked did you research at all for this build? A simple H/C setup could've yielded more than what you wanted, with less $ and also alot less work.
Also i really don't see why you're going to keep the stock manifolds and make your goal even harder to reach.
IMO you could've went with an LQ 6.0 threw your cam in milled the heads done full bolt ons and you would've reached your goal and then some.
Edit: I can't understand how you can justify buying yella terras and not LTs lol its beyond me.
Now on a FAST 102 intake, keep it. They're definitely not a waste and have proven to give gains even on a stock LS1 with no low end loss. They'll also support a 700hp+ application without being a restriction.
Jason
