View Poll Results: cam/stall combo
228r
44.83%
Torquer V2
20.69%
custom grind
37.93%
3200 stall
3.45%
3600 stall
62.07%
Multiple Choice Poll. Voters: 29. You may not vote on this poll
cam help for dd
Old Sep 19, 2012 | 08:09 PM
99Bluz28's Avatar
A TSP 228/228, or a 228/232 would work great, and a 3200-3600 stall.
The largest cam I'd go with would be a 232/234.
Old Sep 19, 2012 | 08:48 PM
1nasty86's Avatar
Turd Gen Guy
228/232 would be a great cam.... use a xer intake lobe and a xe exhaust lobe.....great cam and they make good power
Old Sep 19, 2012 | 09:45 PM
arock24's Avatar
Originally Posted by 98gtp
Anybody run the torquer v2 or the g5x2?
v3 here...works great with a 3600 too. No need for anything bigger than a 3600 unless you're going to the track more often IMO. I mainly cruise, only see the track about 3-4 times a year. No regrets on my set up.
Old Sep 19, 2012 | 10:01 PM
Sales@Tick's Avatar
I've got a 226/230 114+4 that would make a great DD cam and go with the heads you plan on buying in the future.
3600 stall with 3.73's would be a really nice set-up.
TXZ28LS1's Avatar
FYI, my 4000 stall drove just as easy as my 3200. Circle D 5c btw.. I was iffy on that big of a stall, but i will take a 4000 stall anyday over a 3200, 3600.. I have personal experience with one. A 3800 will be perfect for a daily driver setup.
My car was also just a fun street car, light to light, daily driver. No problems at all. My old X1 cam, reverse split, 3.73, and 4k stall woke up big time. It pulled vicious up top than it did with a 3200 stall. More fun to drive.
4k might be too big of a stall, but its not. Thats why i suggested a 3800.
Old Sep 19, 2012 | 10:28 PM
Sales@Tick's Avatar
I would like to see most everyone use a slightly bigger stall than they were planning on. It only helps numbers at the track which sooner or later they will care a lot about a and making the car feel faster.
When they begin to worry about less fuel mileage and drivability, that's when I say, "That's what lock-up converters are for."
Old Sep 19, 2012 | 10:48 PM
BirdsSince16's Avatar
When they begin to worry about less fuel-mileage and drivability, that's when I say, "That's what Hondas are for."
Old Sep 20, 2012 | 07:34 AM
Sales@Tick's Avatar
That too!
Old Sep 20, 2012 | 08:02 AM
1nasty86's Avatar
Turd Gen Guy
Circle d 4000 here..... drives like stock when the converter is locked
Old Sep 20, 2012 | 08:38 AM
thunderstruck507's Avatar
I wouldn't go lower than 3200 on the converter or eventually you will just be kicking yourself.
My SS3600 is tight enough it seems very tame at part throttle even in a heavier car than most fbodies. On the highway it drives like stock of course since it locks up.
Old Sep 21, 2012 | 06:29 AM
TXZ28LS1's Avatar
Exactly!! My circle D 4000 is amazing.
Old Sep 21, 2012 | 07:36 AM
  #32
mjs1012's Avatar
I dd an ss3600 and its a great converter and very tight for what it is, I wouldn't go any lower personally.
Old Sep 21, 2012 | 08:45 AM
  #33
Exactly. A SS3600 will drive like what most people would expect from a 2500 converter...until you really hammer on it, then it comes alive and the car will fricking move.
Old Sep 21, 2012 | 11:28 AM
  #34
MikeWS6's Avatar
The 228R is the biggest I would DD. Anything over that would just annoy me.
Old Sep 22, 2012 | 08:23 PM
  #35
98gtp's Avatar
So a 228r with a 3600 would be pretty good? I just don't wanna regret not going bigger. What gains can I see with that setup and cnc z06 heads?
Old Sep 22, 2012 | 09:58 PM
  #36
I honestly think you might be happier with a v2.
Old Sep 22, 2012 | 10:16 PM
  #37
98gtp's Avatar
On a 111 or 112 lsa?
Old Sep 22, 2012 | 11:53 PM
  #38
Mine's on a 111 and I love it, but it's not exactly the v2. Just the same specs on a grind from Comp.
Old Sep 23, 2012 | 07:42 AM
  #39
98gtp's Avatar
Is there much of a difference with lsa? Isn't lower lsa more for top end? I'm sorry I don't know too much about cams
Old Sep 23, 2012 | 11:49 AM
  #40
MikeWS6's Avatar
I think you would be more upset if you over cammed your car. I vote for the 228R but the TV2 is a great choice as well. I almost ran that cam.
