View Poll Results: cam/stall combo
228r
44.83%
Torquer V2
20.69%
custom grind
37.93%
3200 stall
3.45%
3600 stall
62.07%
Multiple Choice Poll. Voters: 29. You may not vote on this poll
cam help for dd
Old Nov 26, 2012 | 09:15 PM
  #61
98gtp's Avatar
Rpm range? Would a torquer v2 on a 111 lsa be better then a 228 on a 112
Old Nov 27, 2012 | 08:07 AM
  #62
Sales@Tick's Avatar
I would personally do the torquer on a 112. If it was a manual and staying cam-only I'd do the 228 on a 111 or 112 or the torquer on a 111.
Old Nov 27, 2012 | 08:16 AM
  #63
greenvortec97's Avatar
I say he needs some of that street heat.. LOL
Old Nov 27, 2012 | 12:12 PM
  #64
Sales@Tick's Avatar
I appreciate the kind words, I just don't like to come into another members thread that already has decided on another companies camshaft and "pull the rug" out from under them so to speak. I don't think it's polite or a good way to do business.
Old Nov 27, 2012 | 07:55 PM
  #65
98gtp's Avatar
Thx I was Jus using those two as examples n those r the two i keep hearing for a dd cam
Old Nov 28, 2012 | 01:03 AM
  #66
ZTwentyAteU's Avatar
The 228r with no split will be a little smoother from what i've exp with it. My tv2 was bucky and I just never could get it to stay smooth, no matter what fuel or timing I threww at it. It was one reason i sold the car it was in, now i'm picky so you might not even care, and being an auto would soak up some of that. Made great power though, 425rwhp and 400tq in a lq9 with just the tv2, longtubes and ls6 intake. 630hp on nitrous, that cam loved the juice for some reason
Old Nov 28, 2012 | 01:22 PM
  #67
98gtp's Avatar
How much of a surge was there. I dnt want too much bucking that I'm guna regret the cam.
Old Nov 28, 2012 | 05:35 PM
  #68
JakeFusion's Avatar
Super Hulk Smash
Martin can certainly help you out.
Also, look at an EPS lobed 226/234. That thing drives nice and puts out beastly numbers.
Old Nov 28, 2012 | 05:49 PM
  #69
ldyzluvdis06's Avatar
i daily a tv2 with a ss3600. mine is not bucky at all, and makes for a nice DD. i love it. i have been wishing i would have went with a little bit more of a cam though.
Old Dec 1, 2012 | 03:13 PM
  #70
98gtp's Avatar
Rly? Wat power u puttin dwn
Old Dec 1, 2012 | 05:04 PM
  #71
havn't been dynoed.
i also use to have 2 gtps, one with IC and rockers and 3.0 pulley, and another turbo'd
Old Dec 1, 2012 | 08:10 PM
  #72
98gtp's Avatar
havn't been dynoed.
I loved my gtp. Ported blower, 3.0 pulley, Exhaust, tune. I wish I turbo'd mine tho
Old Dec 1, 2012 | 08:32 PM
  #73
FAD2BLK93's Avatar
Read all of this posting and i see no track times for any of these cams...T2, 224, 228 ect, ect. Has anyone taken thes cams to the track? IMO a SS3600 would be a great middle of the road a around stall for MANY cams. So offer em up, track times and what cam and stall? I'm looking for 11.5@? Setup so i DO NOT have to install a cage. Thanks
Old Dec 1, 2012 | 09:03 PM
  #74
JakeFusion's Avatar
Super Hulk Smash
Lots of people are running those cams. TR224 was the cam of choice 10 years ago. Then everyone went huge. Now they are coming back to smaller cams with lots of head flow. Makes more power and drives better.
Also the SS3600 or equivalent would be an excellent driver. FTI has a 3600 which is just as tight but might outrun it. CircleD has a 3500 that's not quite as tight but can still be driven no problem.
Old Dec 1, 2012 | 10:23 PM
  #75
99Bluz28's Avatar
Originally Posted by spicebird98
i have a feeling that a 227/230 .614 .609 114+3 would spark your interest and would work well with a 3200+ stall
This would be a very good cam for him to go with, if he's willing to go with the higher lift, or if he want a less aggressive intake lobes then the 226/230 114+4 that Martin suggested would also work really good for his needs/wants.
Old Dec 12, 2012 | 08:00 PM
  #76
98gtp's Avatar
That's a pretty high lift
Old Dec 13, 2012 | 12:59 AM
  #77
badassracing's Avatar
I dont think "bucking" is going to be a problem with the v2 in an auto car with a stall. That would be a m6 problem. If your looking at running a stall around 3600 I dont see the v2 being a problem at all.
Old Dec 14, 2012 | 04:01 PM
  #78
JakeFusion's Avatar
Super Hulk Smash
Unless you're in lockup in OD cruising at low speed ~ 42mph/1600rpm or so in a congested area. If you have too much overlap no amount of tuning or stall will help. M6, I agree is worse, especially at lower gears.
But the T2 doesn't have a ton of overlap. Anything below 8 degrees should drive decently. Anything below 4 will drive well.
