Help: TSP cam install
Old Apr 8, 2004 | 04:16 PM
WS6dan's Avatar
Default Help: TSP cam install
I just ordered the TSP cam special yesterday with 231/237, patriot duel spring, retainers, and gasket kit. Do I need anything else like the upgraded oil pump or a different timing chain, any help would be appreciated. Also is this cam a XE or XE-R. This is going in my 02 ws6 ta.
Old Apr 8, 2004 | 04:20 PM
ChevyThunder17's Avatar
Here's a little help for you...
http://www.ls1howto.com/index.php?article=2
Old Apr 8, 2004 | 04:44 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Having a 2002 car prob will not really need an oil pump or timing chain unless you want one. The oil pump is usually worth 5-10psi over a stock pump. 98-00 cars were the cars that had problems with stock oil pumps. The 231/237 camshaft isn't a Comp Cams XE or XER grind, its custom ground by Lunati for us. If you do the oil pump, be careful with the pickup tube o-rings, there have been allot of problems with the o-ring getting pinched or falling outta place.
Also LS1Howto.com is a great website for installation instructions.
Old Apr 9, 2004 | 12:33 PM
WS6dan's Avatar
Thanks for the help
