well it rebuild time
anyways i notices a new noise afterwards. first thought was i spun a bearing so got home started pulling the motor out and started to break it all down and i see this
and then this in the bottom of the pan
but also before the missed shift i notice oil pressure dropped like 2 months before hand so i had already planed to crank open the motor and repair and replace parts so after digging deeper in the motor all the bearings are looking really good and then i hit number 7 and then i see this
so now i sent out the crank to get worked on and the rod getting inspected to see if i can reuse it or replace.
oh this all happened with 133xxx miles on it figured it would be time to refreshen everything up from all the years of abuse and the abuse i put in it
