any truth to this info...???
If I remember correctly the LS6 (243) stronger spings than the LS1 (241) -
Hands down the LS6 head flows better than the LS1 due to the runner volumes and the smaller combustion chambers!
LS6 heads are refined and improved LS1 heads, basically:
- Intake runner volume increased to 210cc vs. 200
- Exhaust runner volume increased to 75cc. vs 70
- Combustion chamber is smaller at 64.45 cc vs 66.67
- Compression ratio is higher at 10.5:1 vs. 10.1:1
- "D" shaped exhaust ports vs round
If you mill the deck on the LS6 head 0.030" you will get 11.1:1 compression.
Flow #'s (Stock heads @ 28") Head vs Lift
Head/.200/.300/.350/.400/.450/.500/.550/.600
LS1 / 137/ 187/ 207/ 223/ 228/ 237/ 242/ 243
LS6 / 156/ 204/ 225/ 243/ 257/ 268/ 275/ 278
In short smaller and more efficient combustion chamber allows quicker burn times, requires less ignition timing resulting in higher torque.
Stock bottom end 346?
What size chambers do you have? - cc's?
headgasket thickness?
How much did you mill your head?
If more than .060, did you run into any intake manifold fitment issues?
Stock 346, .05 stock mls gasket
Pistons are out .008
Heads are 46.x cc
best guess is they are milled around .135-.140, do not remember what was taken off the first time. Calculated at 12.96:1
Dynamic compression is 9.65:1
