head question
I currently have a 227/231 613/617 111+4 Lsa comp cam and stock 241s if I get the heads milled to bump up the compression will my pistons need to be flycut with that size of cam all input is good thanks.
I don't feel like buying 243s so I've been reading that a set of milled 241s with my kind of cam would yield a nice tq curve
How much milling will I need to get my 241s compression 11:1 I still would like to run 91 pump gas all motor no power adders
Ok will milling those heads be better then let's say stock 243s? And My friend has some slightly ported 241s I think they have smaller combustion chambers or larger can't remember the bigger valve is a 2" idk if that's stock size or not
