How much more Spring lift can you run than Cam lift?
Say you have a .600 lift cam, What is the largest spring lift you can run? Or does it matter. Ex: .610,.630,.650?
There is really more to matching a set of springs than just matching the lifts.
You could have coil bind on one spring that equates out to .650" lift that has more open and seat pressure than a spring that has coil bind at .675" lift that has less open and seat pressure.
You'll want to match your springs to the weight of your valve-train and the lobes your cam uses.
The more aggressive the lobe and/or the heavier the valve-train the more spring pressure you will need.
Ok. The reason I'm asking is bc my car came with a aftermarket cam but I don't know the specs of it. And I have a set of 243's I want to put on my ls1 but I don't know what springs to get.
http://www.briantooleyracing.com/660...l-springs.html
They're a tremendous upgrade to anyone running the Gold springs.
Yes they will! You can purchase just the Platinum springs and they drop right in place of any Patriot Gold or Xtreme springs!
my golds are getting tired (Trex cam), might give these a try...Great deal!
