shoud I be using head bolts or studs?
Old Oct 13, 2012 | 10:30 AM
THE LAST Z's Avatar
Default shoud I be using head bolts or studs?
Im putting together a 370 ql9 with 317 heads and eventually a procharger. Can I use arp head bolts? Or should I use studs...
Old Oct 13, 2012 | 12:18 PM
2000PewterT/A's Avatar
I used ARP head bolts just because if I ever need to pull the heads off the engine I have the room to pull them out without the studs being in the way.
Old Oct 13, 2012 | 01:46 PM
THE LAST Z's Avatar
Oh.. Good point.
Old Oct 13, 2012 | 02:29 PM
96capricemgr's Avatar
You should use whatever the shop used when they torqued down the deck plates for boring the block.
Old Oct 13, 2012 | 03:12 PM
Another great point I forgot to mention, When my block was machined I had them use my head bolts. That is the only proper way to do it.
Old Oct 13, 2012 | 03:32 PM
Blu99T/A's Avatar
I prefer the studs due to the clamping force, less prone to pull threads and if you swap heads enough, you wont wear out the threads in the block.
Head studs make for kick *** pic's too..haha
Old Oct 13, 2012 | 03:44 PM
Sales1@Texas-speed's Avatar
Really depends on your plans with the build, but if its in the budget stud it!
Old Oct 13, 2012 | 08:42 PM
1nasty86's Avatar
Turd Gen Guy
Do it once and do it right.... stud that ****
Old Oct 13, 2012 | 09:06 PM
I think most of us understand studs are better BUT when he says "putting together" we have to wonder how far the project is. If the shop already bored it with bolts......................
Old Oct 14, 2012 | 05:48 AM
RezinTexas's Avatar
can't you just take the studs out before you pull the heads?
Old Oct 14, 2012 | 09:11 AM
Blu99T/A's Avatar
sure can
Old Oct 17, 2012 | 09:04 AM
THE LAST Z's Avatar
I guess ill go with the studs. Thanks everyone..
Old Apr 11, 2021 | 10:33 AM
crewguy's Avatar
ME TOO! Part number for a 4th gen?
Old Apr 11, 2021 | 11:19 AM
ARP 234-4316 for 97’-03’
ARP 234-4317 for 03’ and up LS engines
Old Apr 11, 2021 | 01:35 PM
01CamaroSSTx's Avatar
ARP 234-4344 is the 12pt stud kit for the 03 and earlier.
Old Apr 11, 2021 | 04:27 PM
Little stronger material makeup, with a little higher price, vs. the 234-4316 kit. Both are 12pt. fasteners for 97-03 LS engine.
Old Apr 11, 2021 | 05:00 PM
I didn't know that Scott and they damn sure weren't cheap either.
