very strange oil pressure issue
just put a new (used) engine in and i'm having some very strange problems.
if I put a mechanical gauge at the front port on the left side of the block I get good pressure from 25-75psi
if I put the mechanical gauge at the rear port behind the intake where the factory sensor is I the oil pressure never gets about 35psi
I pulled the engine and looked at the mains, the bearings on 2 of them have some minor grooving, but nothing major. The tolerance with a plastigauge at the front main is .0015
did a compression test and all cylinders were exactly 210psi. The compression numbers along with the bearing clearances points in the direction that the motor is relativity tight.
Pickup tube oring was not pinched
using a standard volume standard pressure oil pump
rear dogbone/barbell is installed
any thoughts on what is going on?? I'm completely stumped
