Need help calculating 5.3 compression
Old Nov 6, 2012 | 03:35 PM
northcorner's Avatar
Default Need help calculating 5.3 compression
I'm not asking anyone to calculate it for me. I need the dish cc for stock '04 LM7 pistons, and how far out of the hole are they ( if any). I tried the search feature, google, etc. with mixed results.
Old Nov 6, 2012 | 06:01 PM
batboy's Avatar
I thought the LM7 used flattop pistons? As for how far out of the hole, you have to measure it. But, LS engines typically are about .005 to .006 above the deck.
Old Nov 6, 2012 | 10:05 PM
Thank you for your reply. .005 to .006 has been the consensus on how far out of the hole the stock piston is, so far. The '04 LM7 pistons have a dish, it appears that the dish is the same on all LM7 engines, but so far no one has a spec on them. I thought for sure that GM had some info, but I just can't unearth it. I'm not sure why it's so hard to find a measurement that is blueprinted with GM, on such a popular platform.
Old Nov 6, 2012 | 10:41 PM
batboy's Avatar
Vortec 4.8 / 5.3 differences: GM used a shorter stroke crankshaft in the 4.8L and a longer connecting rod. 99 to 03 or so, the 4.8L's all had completely flat top pistons. 5.3L's had a slight dish. However, after about 2004 sometime, the 5.3L's could have true flattop's. So really the BEST way to tell is measure stroke, or casting number on crankshaft. Of course if you are standing in-front of a vehicle, you can look at the VIN#. 8th digit is the Engine, 10th digit is the year. T = 5.3L LM7, V= 4.8L LR4, Z = 5.3L L59 Flex Fuel
Does your pistons have a true dish or just small valve reliefs? I've seen several references that said -2cc valve reliefs.
Old Nov 7, 2012 | 08:54 AM
They have a true dish. I've also seen the 2cc reference, but also seen a 7 to 8 cc reference, but nothing definitive.
Old Nov 7, 2012 | 10:47 AM
batboy's Avatar
Maybe I'm thinking of the L33 having flattops.
When I crunched the numbers on the compression ratio calculator, looks like the dish is probably about -7 to arrive at the advertised stock CR.
Old Nov 7, 2012 | 12:24 PM
chrisfrost's Avatar
Hello , I measured My 1999 5.3L stock dished pistons at 9cc
Also a really good source for engine and car calculators is Wallace Racing . They have evry calc You can think of and many more like static comp, dynamic comp, all You're cam calcs, 1/4 n 1/8th mile et, gear ratios, check it out honestly there are probably 100 to 150 different calcs maybe more and They're free
As far as piston out of hole ,,,,,,,I could'nt get an exact measurement but I used feeler gauges and it appeared that They were out of hole roughly .015" ,,,,,,hope this helps
Old Nov 7, 2012 | 12:29 PM
Thank you guys.
Old Nov 7, 2012 | 12:50 PM
chrisfrost's Avatar
You're welcome ,,,,,,,,,and I edited My last post .
Old Nov 7, 2012 | 04:36 PM
zpi28's Avatar
What is the advertised Comp. of the LM4?
By Brett Foote | 2026-06-04 05:00:17
