Some jealous guy got me worried?
Better off going ahead and using ARP on the mains and rod bearings and resizing the rods back to true with the proper bearing for the new diameter. Shortcuts will end up costing you in the long run. If it is worth doing it is worth doing right the first time.
Note- this is sarcastic to some degree, especially after a rain. Not trying to start a LT vs LS battle, just thought it was funny he said that. I know tons of people back in the day that spun bearings within a few hundred miles of a cam install on a LT. Cheap insurance is new GM pump with white spring.
My advice OP, save you up a little change for a rainy day engine fund, and drive it however you want. With good routine maintenance, and conservative rpm, you're engine should have plenty of life left in it. With a modded engine, reliability goes down. So when it goes ONE day, replace or repair it and start the cycle over.
Dont worry about it. **** happens at any mileage. My ls1 put TWO rods through my block and ate a piston at 97k and you know what I was doing? Starting it up, thats it, but boom she went.
PS, dont mean to hijack the thread OP!
2001+ cars had better rod bolts and can frequently spin to 6500 without to much concern. The earlier cars had the bad rod bolts that tended to stretch and were a different design. Those are prone to fail, especially with rpms over 6000.
Any rod bolts EXCEPT katech WILL REQUIRE RESIZING.
