Advanced Induction 5.3L Heads (218cc) - Thoughts?
I've been looking at cylinder head options and been considering TFS As Cast heads as well as PRC Stg 1 LS6 heads and now Ai's 5.3L heads. I've also thought about sending in my 241s and letting Ai weld up the chambers and port them. I've asked Phil @ Ai to provide a break down to what the difference would be between those two options other than the cost of new 5.3L heads.
The budget for heads is in the $1500 range, though I can certainly go a little bit higher. From what I've seen, I'm not giving up much with any of those options, especially with the TFS As Cast. Those can be hand finished and be as good as the TFS 215 while being a lot less expensive.
But the intriguing thing to me is the Ai heads with either stock valves or lightweight Manley valves that are stock size. Lightweight valvetrain is a big plus for me, and I'd be willing to upgrade the TFS heads to turned down LS3 valves with PM guides installed for the lightweight stock rockers.
Either way, I've seen some very impressive results with Ai, but wanted to hear from other owners out there.
Right now, my combo is shaping up to look like this in my 02 A4 T/A:
Comp LSL/LXL 231/238 .617"/.615" 113+3 LSA Camshaft
BTR Platinum .660" Lift Dual Valvespring Kit with Ti Retainers
Comp Trunion Upgrade with stock rockers
FAST LSXR 102mm Intake Manifold with FAST 92mm TB
TSP 1-7/8" Longtube Headers with Off-Road Y-Pipe
Magnaflow Catback
Powerbond UDP
FTI 3600 Stall
I'd probably run a 59 or 58cc chamber with the stock MLS gaskets for an 11.5:1 or 11.6:1 CR which will work well with that cam.
https://ls1tech.com/forums/dynamomet...-gm-5-3-a.html
The HCR 219 option is very tempting and very much within budget. I've seen As Cast TFS pick up 54rwhp with an UDP (so I'll call it a solid 50), but I've also now seen the Ai heads pick up 40+ every time they are put on a car in the dyno threads and usually closer to 45-50.
Jason
I'm also thinking of running a bigger cam here in the last few days and would need to get down to like a 57cc chamber to get the compression up to suite the cam. I love the idea of the smaller chamber that still flows crazy good to help a big camshaft out. If Phil can alter the PtV clearance a bit, then I think I'm golden
Just waiting to hear back from him. Jason
Just waiting to hear back from him.Trending Topics
Still good numbers.
casting then it's hard to beat an AI or a TEA cnc port job. Both of these
reputable vendors have a real stranglehold on maximizing flow from a small
volume runner/valve combination. Can't go wrong with either !!!!!
Also, my combo keeps changing in my mind (about to pull the trigger on the cam, so that'll sort of lock me in). Bigger cam, bigger stall, and maybe a louder exhaust like the GMMG (or cutout for the Magnaflow). Either way, the Ai heads with their high velocity and good flow match up well with either cam I go with in terms of overall combo output.
Below is the thread I started with all the details of how my build. It was all on the same dyno.
https://ls1tech.com/forums/showthrea...2#post16271962
Jason
I'm also going to use either one of his custom grinds: 226/234 .600"/.600" 113 with 11.5:1 CR. Has easier lobes. Or the more aggressively lobed profile of 228/236 .626"/.626" 114 with something like 11.3:1 CR (due to clearance issues). Right now leaning to the bigger cam (still very streetable).
For $1995 the package includes:
Ai HCR 219cc Full CNC Porting Package
Ai Custom 228/236 .626"/.626" 114 LSA Camshaft
Ai Hardened 4130 ChromeMoly Pushrods 5/16" x .080 Wall x 7.xxx
GM MLS Head Gasket .051" Compressed
BTR Platinum .660" Dual Spring Kit w/ Ti Retainers Upgrade
And for another $195 Phil will install the Comp LS Rocker Arm Trunion Kit into my existing rockers. I'll just send them in with my heads to get all the work done. I'm also going to pick up an Ai ported LS6 oil pump.
Should be good for 85-100rwhp over stock heads/cam.
Can't wait to see your results should be impressive...heard nothing but good things about AI.
The 226/234 was one of the options. He just added the 228/236 has more aggressive lobes. That's why the BTR springs are recommended to control the profile. For the 226/234 he recommends the PSI 1511 beehive spring.
I just sent him a note asking what the power difference between the two would be. It's a $50 difference in price for the package (cost of the BTR springs). So it comes down to performance vs reliability. I may still go with something like an EPS 226/234 since I know that cam rocks the hell out of whatever it's in. But the point is, all those cams carry a very similar profile and that's pretty much what I want - good manners, broad power range, and power carried cleanly to 6700 or so.
The LS7 can only take so much before it gets noisy. Heavy valves, huge spring pressures, and aggressive cam profiles all will cause the LS7 to bleed down more at idle and make more noise.
