Can I run the engine without rockers?
I read into this a few years ago on another forum. The best way to do this is take whichever cylinder to BDC before you release the rockers and the air will act like a spring when you run it. It will not harm the motor. This method has been around for years.
There was a recent thread that had a similar problem. It got worse with aftermarket valve springs. I will see if I can find the thread, but he did the trunnion upgrade and it helped immensely if you are running stock rockers.
Found the thread, hopefully it has some good information: Link
How go You do compression test ? You disable the fuel/spark to all cylinders and put tester in 1 cyl at a time which won't hurt a thing . Lifters will also be just fine with p-rods removed . Before You try that with 1 rocker cover removed at a time ,,,,,,,,squirt some oil down 1 or both p-rods at a time and start it and listen for quieter operation ,,,,,,,,the oil will make it to the lifter and lubricate the lifter for a few and quiet a lifter that has been a little too starved for oil .
I am terribly slow and take my sweet *** time. Even with very few hangups it took me 3 days to do the head/cam swap
So I got around to doing this tonight. What I did was remove the both rockers and pushrods from a cylinder. Rotate the engine until that cylinder was at BDC. Left in the spark plug. Unplugged and injector and coil for that cylinder. Did this for cylinder 5 and 7 where the noise is coming from. And when I did cylinder 5 the noise was significantly less. I did cylinder 5 twice just to confirm, same results both times.
The preload on this cylinder is 0.091 on the exhaust with a 7.350 pushrod and 0.084 on the intake with a 7.325 pushrod. Putting a 7.325 pushrod on the exhaust valve did not change the noise. I may try a 7.350 on the intake valve to see if it makes the noise better or worse.
Both lifters are physically fine from what I can tell through the valve cover. They bleed down fine when tightening the rocker and pump back up when removing the rocker. I can't push them down by hand. Both rockers are fine, springs are fine.
With the engine running I also just unplugged the injectors and the noise did not go away, so it's probably not something related to the combustion.
Anyone have anymore thoughts? Sounds like it might be a bad lifter, but I was hoping to be able to physically tell that the lifter was bad.
One last ditch effort may be to put Mobil 1 10W-30 back in since the noise started shortly after putting in Rotella 5W-40.
check for a bent pushrod, it doesn't take much of a bend. Also check to make sure the pushrods aren't touching the head. I never liked 5w oil. Also make sure the rocker isn't touching the baffles in the valve covers.
