Cam swap/ Stumped please help/update/got her running
Ok so I was finishing up my build put my heads on spun motor by hand everything seemed fine tried to fire her up won't start... So I was thinking maybe I installed cam off by a tooth took off over cam is perfectly aligned I tried to spin motor this time it gets to a certain point then seems like its stuck I turn counter clock wise get to a certain point then feels stuck I'm stumped and don't know what to do anyone know what the first thing I should do??
Did the motor just turn over when you tried to start or did it make any popping or backfire noise? Also your car is a 98, if you're still using the 98' coil harness, you have to make sure the the LH & RH harness are not swapped.. The car will not run if they are.. The pin-outs are different from 99-02 models that can be swapped. If you still have your factory rocker arms, I would throw those back on & try again.. I can't see 7.4's being to long on un-milled 243's.. I run 7.425's on my 243's with a much larger cam.
