scorpion roller rocker arms
the scorpion rockers are good, but not made for daily driving.
less prone to failures than the Harland Sharp rockers, and they are a Much better rocker than YT's/Harland/Comp.
but if I was going to Daily Drive them, for the price, I would buy the YT's or a set of Comp rockers...
or, you can spend a few more dollars and buy a set of Jesel's and not have to worry about anything.
they arent very good, and neither are the YT's, theres only about 100 threads about them both breaking and ****.
stock rockers are just fine with the trunion upgrade unless you need roller rockers for heads with bronze valve huides, OR you are running more than .630 lift.
otherwise, stock rockers gets my vote
I've been running the scorpions for nearly 10k miles with redline set at 7k since the car pulls till about 6800. No issues at all. Their ONLY downside is that they are a tad heavy over the nose. Most documented failures are from the OLD scorpions. But folks bring the old info back up. The have a lifetime warranty.
I would also vote for the stock rockers with trunion upgrade if lift isn't too crazy.
Some of the Jesel rockers are not designed for high lift due to the design of the bottom of the rocker. Check this out if considering them and call Jesel and speak with them. Last I knew (which was a couple of years ago) they had not changed the design for higher lift.
