Weird lifter/valvetrain noise
Old Nov 30, 2012 | 10:49 PM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
We definitely recommend swapping out to the LS2 trays when replacing lifters.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old Dec 1, 2012 | 04:31 PM
OffspringZ28's Avatar
heres mine for comparison
Old Dec 1, 2012 | 04:47 PM
KevinR's Avatar
Sounds like a lifter to me. Mine sounded exactly the same way when one of my lifters took a dump. Good luck.
Old Dec 8, 2012 | 03:25 PM
SpdJunkie's Avatar
Well, finally got the valve cover off to take a look at the rockers and found a needle bearing took a dump. Ended up breaking the cage that holds the needle bearings in place. (please forgive if the lingo is incorrect). Ill post a pic of two as soon as i can. What would be the best course of action for me now? Replace the one bearing that took a dump or do a full trunion upgrade? Thanks in advance!
Old Feb 17, 2013 | 10:05 AM
Roarin_8's Avatar
Mine is getting louder. The guy I go to, checked it out and the noise gets really loud above 2000 RPMS. We are going to pull the valvecovers soon. The car is going to sit till then. I'm hoping that just something broke up top, don't want to tear deeper into the motor.
Old Feb 17, 2013 | 08:23 PM
BKsNHRA's Avatar
Get the comp trunion kit. Very easy to install if you have a vice. Read the directions. Make sure to put the new bearings in the correct way. Problem solved.
