Need help finding a crank pulley removal tool
I just pulled my crank pully off today and I used the Chrysler crank puller from autozone and it was the best and easiest for me, I tried the bigger jaw pullers with no luck this one is compact and beefy and took it off no problem at all
Is there a special technique .. I loosen the bolt and grabbed the pulley with jaws w/ the bolt still in but really loose . I was using the bolt to apply pressure to pull the pulley off
Some of the kits have a peculiar pushrod looking setup in them as well. It took me a while to figure out how to get it all together when I couldn't get the crank off my LM7 with the stock bolt. There's a little angled piece that fits into the opening where the bolt goes that a pushrod fits into, then the pulller pushes off of the pushrod. Sounds complicated, but if you have the right parts in your kit then you should be able to figure it out.
