Lifter Tray Bolt Missing
Old Dec 2, 2012 | 12:20 AM
98WS6Hville's Avatar
Default Lifter Tray Bolt Missing
So, I'm piecing things back together and I'm missing one of the four lifter tray bolts. Great, right? Kinda frustrating. Does anyone have any idea if I can get one local? I live in a decent sized city with places like Home Depot, Lowe's, Advanced Auto Parts, Napa, Auto Zone, etc easily accessible. I'd like to pick this up locally as opposed to having to order yet another part online. Trying to get this project done soon..
Thanks in advance.
Old Dec 2, 2012 | 12:34 AM
slamminjim's Avatar
Maybe disclose your location and maybe a fellow tech member will have one.
Old Dec 2, 2012 | 10:01 AM
Huntsville, Alabama.
Old Dec 2, 2012 | 10:50 AM
Sales1@Texas-speed's Avatar
I recommend grabbing one of your other lifter tray bolts up and running down to some of those local parts stores and see if you can match something up. Hopefully you'll get lucky and one of the autoparts stores will actually have a replacement bolt to make it simple.
Old Dec 2, 2012 | 11:03 AM
GMtechmatt's Avatar
i recommend getting a new tray and bolt from the dealer or a speed shop that has the Gm lifter trays ands bolts
Old Dec 2, 2012 | 11:11 AM
wildcamaro's Avatar
I believe it is 8mm x 1.0...but just match an old one up, if u can't get one with a shoulder than use a washer...
Old Dec 2, 2012 | 11:22 AM
2002ss335's Avatar
Take one to Fastenal, they have just about anything you would need.
Fastenal
2900 Triana Blvd. Suite A
Huntsville, AL 35805
Todd
Old Dec 2, 2012 | 12:04 PM
Tally TransAm's Avatar
with the shoulder design on that bolt that's one I would get from the dealer
Old Dec 2, 2012 | 12:17 PM
427's Avatar
427
It is very important that the bolt not tighten on the lifter tray, it cannot be locked down as this can cause failure. Get the factory bolt if at all possible.
Kurt
Old Dec 2, 2012 | 12:26 PM
badazz81z28's Avatar
Kurt
This makes me curious? What do you mean?
When I pulled my lifter trays a few months ago, the bolt seems press down on the tray...A pic would help.
Old Dec 3, 2012 | 07:42 AM
427's Avatar
427
The bolt has a spacer built in so it tightens against the block before it locks the plastic down. This lets the lifter center the guide while the bolt keeps it from rising up. You need the bolt GM supplies if you replace it, or make a proper spacer.
Kurt
Old Dec 3, 2012 | 05:55 PM
Pocket's Avatar
Its just a metric shoulder bolt, nothing special
Dealer will be easiest, fastenal or McMaster would suffice as well, given the people behind the counter are not incompetent like those working around here
Old Dec 3, 2012 | 06:25 PM
Problem fixed. Thanks for all the quick replies. You guys have been a great help, as always.
Old Dec 4, 2012 | 09:43 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
GM #12551163 is the one you want and need, if you haven't found one already!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
