View Poll Results: Piston Slap Poll
Have had serious occuring engine problems/damage/failure.
2
1.43%
Have ticking/knock on cold startup for 30 sec.
50
35.71%
Have loud ticking/knock continously.
18
12.86%
Have severe oil consumption.
5
3.57%
Have engine and performance# loss under 0-50,000 miles.
2
1.43%
Have engine and performance# loss under 0-25,000 miles.
3
2.14%
Have had NO engine and performance# loss over 0-75,000 miles
39
27.86%
Have had NO engine and performance# loss over 0-100,000 miles.
21
15.00%
Voters: 140. You may not vote on this poll
Piston Slap Poll
Old Oct 28, 2007 | 12:00 PM
NemeSS's Avatar
have a 02 silverado with 110k miles, engine runs strong.
is used to tow boat, car and trailer, has some piston slap upon startup
for about 10-15 sec., oil consumption no more than any other ls vehicle ive owned,never noticed hi oil consumption, valvetrain noise or slap in 5.7 i owned before
Old Oct 28, 2007 | 12:20 PM
onoiocoko's Avatar
what would cure this? i believe its in the design of the motor so it would probably come back, but if im in the motor i would like to fix it. thanks.
Old Oct 28, 2007 | 12:41 PM
dug's Avatar
dug
When it was cold, mine slapped so bad it sounded like a diesel. It still ran like hell when I sold it. My oil consumption seemd to be from the pcv. When I swapped intakes the original one was dripping with oil. If I get another ls1 its gonna have a breather
Old Oct 28, 2007 | 01:21 PM
Fierotom's Avatar
85k on the odo and light knocking after cold start for less then a minute...
but only after the car sits a few days in the garage....
and no significant oil consumption.....
runs great!
Old Oct 28, 2007 | 01:33 PM
Killer_Z's Avatar
yeah i have a little bit of ticking on cold start once its warmed up its purrrs
Old Oct 28, 2007 | 10:30 PM
CETA_TransAm's Avatar
91,000 no problems with motor
Old Oct 28, 2007 | 11:03 PM
Sunset'01Z's Avatar
i have 101k on my car, 50k of which i put on it. it sucks about a quart of oil in 3k miles, sounds like a diesel, shakes and rattles, but rolls out when the throttle goes down.. gotta love the ls1..
Old Oct 29, 2007 | 07:27 PM
brandons02's Avatar
56,000 miles, valve train tick, all the time
Old Oct 29, 2007 | 08:36 PM
Lickeyman's Avatar
kinda diesel-ly for the first min or so. Especially when cold because it isn't garaged. Sound disappears by the time the temp gauge gets a little bit past the first mark.
91k and runs like a bat out hell so I don't think there is a prob. 1/2 quart between changes (maybe that much)
I just don't romp on it till proper operating temp
Old Oct 29, 2007 | 08:47 PM
CavPat's Avatar
since i installed my cam, mine slaps and sounds like a loud *** sewing machine.
Old Oct 29, 2007 | 11:00 PM
Steve Bryant's Avatar
LS1 Tech Veteran
I would have voted in two categories if I could have.
1. I have mild piston slap in cold weather for 10 to 30 seconds.
2. I've got about 70 k miles and no performance loss, no excessive oil consumption.
I'm extremely satisified with my engine and the mild piston slap is not an issue with me. Most modern engine designs have short piston skirts and are subject to some slap.
Steve
Old Oct 30, 2007 | 12:35 AM
  #32
RevGTO's Avatar
Pontiacerator
I'm extremely satisified with my engine and the mild piston slap is not an issue with me. Steve
I'm with Steve. I don't have much audible slap until it dips below 50 degrees. I find its worse with GC than standard 10/30 oils. Oil consumption is moderate - 2/3k per quart depending on conditions.
Old Oct 30, 2007 | 02:30 AM
  #33
b00sted's Avatar
My car went 13.4 @ 106 with 160k on the clock. Stock w/ just a lid...m6 and regular street tires.
Whether it lost performance or not, I'm not sure...I don't know what it did new. But 13.4 wtih 160k miles on it...I wouldn't consider it having lost much.
Also, it had a minor tick in cold weather for the first minute. Only ticked a little under a load, and went away by the time I got to the end of the block.
Old Oct 30, 2007 | 10:20 AM
  #34
RE AND CHERYL's Avatar
You need some more choices.
: I have no noticable piston slap
: I have barely noticable piston slap for a minute or so after start-up.
Mine bounces back and forth bewteen both of them.
Re'
Old Oct 30, 2007 | 10:24 AM
  #35
Loose piston to wall clearances are the culprit. Built it tighter.
Re'
Old Oct 30, 2007 | 12:46 PM
  #36
lt1camaro95's Avatar
Sounded like a diesel truck. Used a quart about every 1000 miles. Now its broke.
Old Oct 31, 2007 | 12:27 AM
  #37
Do Work Son!'s Avatar
44K miles. noisy valve train, then spun bearing. Think mine was made on monday......
Old Oct 31, 2007 | 12:33 AM
  #38
dug's Avatar
dug
that sux, think the heat made it worse?
Old Oct 31, 2007 | 12:42 AM
  #39
I really think the x3 and the wet 100shot had somthin to do with it. granted it only had 2 bottles of the shot, but PHX only has 91 octane, and i'm not sure if the previous owner ran race fuel when he sprayed it. coupled with the AZ heat, it equaled a 4-5 thousand dollar F%ck up.
Old Oct 31, 2007 | 02:14 AM
  #40
dug's Avatar
dug
haha, didnt know you were sprayin. what did you shift itr at?
