Needing some cam spec advice
Even though you have a "228/232" cam what is the ICL and LSA? Comparing duration and LSA will get you into trouble when trying to compare two cams that have very similar numbers. You need to look at the valve events and where the intake valve closes to compare where a cam peaks.
When I say peak I mean the point in the graph where the horsepower figure has reached it's highest recorded number and then after during the run that number is never eclipsed again. For example:
That is my dyno graph for my car cam-only. My cam "peaks" at 6100-6200rpm, yet carries that peak number all the way to 6600-6700 before it begins to very slightly fall off. Again in reference to my graph, some people would say it peaks at 6600-6700 because that's where it starts to slowly lose power.
With that said, the intake is nothing special, so I am assuming it is the heads that help give it the extra RPMs?
EDIT: With the tight LSA it gets into the powerband VERY fast.
I don't mind the fact that it peaks so high - we will see what it does with a FAST 92/92 setup this year. I actually need the RPMs thru the traps anyway.
Here is a good comparison for you....this car has a stock LS1 bottom end, 243 heads with stock valves that have had a valve job, milled to 11.5:1, Ebay 1x3/4" headers, Fast 78, 3.5" merge, 3.5" cat-back and a 224/236 110+3 camshaft.
His cam has the same IVC point as the cam I recommended to the OP and in my experience in past times doing this exact same profile it peaks at 6100-6200 every time with stock port work and stock valves.
Thanks for the kind words Ryan.
For anyone else interested these are the 6 new grinds that will be released. They will be "torque minded" but still produce very impressive horsepower numbers.
223/226 .610"/.605" 111+2
223/230 .610"/.609" 110+2
227/234 .614"/.612" 110+3 (one of my favorite grinds)
231/234 .617"/.612" 111+2
235/238 .621"/.615" 112+3 (stupid mid-range torque)
235/242 .621"/.615" 111+2
No problem man, I wasn't trying to act like you were wrong, just explaining the process that goes into shaping the power band of an engine.
It's all a product of the combination and how the parts are chosen to work with each other.
