Thunder Racing Trex Cam Idea
to know your guys opinions on this setup. And yes i know i will lose some driveability.
With the ls1 intake and only a cat back, that's about right. You may break 380 but that ls1 intake will not breathe up top where the t Rex makes all it's power.
The problem is, the t Rex won't start making power until close to 4k, and your intake and heads will stall out around 5500. So you really only have 1500 rpms worth of good power
and will flat out suck w\o supporting mods and gears. 4:10s on a M6 10 bolt sounds risky. Thunder is recommending 4:30s or lower and their avertising car is running 4:56s
My 2 cents would be to get the rpm it comes in at 2000rpm or less
99-TR-TORQ-L2 Thunder Racing Custom Camshaft
"TR TRuTorq" Level 2 - 223/230 .609/.604 115 LSA 1800-6500 RPM Power Band. Excellent mid-range & high RPM power. Good bottom end and mid-range torque. Requires computer tuning. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended.
LS6 intake,LT Headers, ORY,Springs, Hardened push rods. Comp trunion upgrade, Timing chain , Oil pump
AI 219HCR heads
AI cam kit
AI ported Fast 102mm intake
Throw in all of the necessary supporting mod and you'll have a solid 440-470hp setup without having to put up with a big donkey dick cam or spending $2000 on aftermarket casting heads. Heck 440hp doesn't sound out of the question with just a LS6 intake instead of a Fast102.
Trex cam on stock ported heads on my blk.m6 its a dog down low but who stays on the low rpm anyway.pulls hard all the way to 7200 rev limeter set.running 4.57 gears on a 9in. rear.
you might have a hard time getting a cam from them TR racing.bad rep lately.good luck.
You should look up opinions and numbers posted from people that ACTUALLY run one, or at least have before. I've gone 11.7 @117 on 1.7 60ft, dynoed 405 rwhp in mid summer heat, and that's a cam only stock 853 head with a few bolt ons (LT, UDP,LS6 intake) and 4.10s out back at 3800lbs. It's VERY streetable, and a blast to run! Is it the best cam out there? No, power band is a little narrow, but it's all about knowing you car.
Aside from that, you'll need to know where YOU want your powerband to be, and in any case, a custom grind cam will almost always be better suited than an "off the shelf" grind.
