Katech employee Dan's 729hp (NA) 6.0L drag race engine
#42
Been thinking about this deal and the comparisons made.......Jason, would you post average data from 6800 to 8200. I believe that even though "peak" numbers are similar (mine made 739 at 8200).......where your combo will shine, with the heads, is in the average numbers.
![](http://i172.photobucket.com/albums/w26/bells67/2010%20Dart-3V%20Performance%20Build/AverageDynoNumbers.jpg)
For the sake of comparison, this is a non RR Dart Pro 1........2.8" MCSA 2.080 valve, that flows right around 350cfm at .900lift. Cam is 272/286 .866/.848 lift. BBC core...... .842 lifter. 7/16 pushrod, 1.65pivot/1.85 ratio stainless rocker, with Ti valves. 11.7:1 compresion, Dart SHP block (nothing exotic) Magnum XL, with Promod rods. Single plane Eddy manifold with a single dominator. 11,000 miles and it is in for a freshen. 2 Drag Weeks.....a 2nd and a 1st. Been a best of 9.71 at 136 and change.......at 3600lbs in my Chevelle.
#43
