View Poll Results: which cam is best
torquer v2
37.84%
torquer v3
48.65%
other
13.51%
Voters: 37. You may not vote on this poll
torquer 2 vs torquer 3
Old Dec 15, 2012 | 06:15 AM
  #81
Ronny_02_WS6's Avatar
I'm running the TRAK cam with stock 241's and Comp cams trunion upgrade, is the same specs as TV3 but 112 LSA. I was running it in 3.42 gear in M6 but I'm in the process of 4.10 right now!!!
Old Dec 15, 2012 | 07:14 AM
  #82
camaroboiss's Avatar
Bet your gonna miss the top end...
Nice.is it a street car or a track car
And what kind of mileage do you get.....I know big cam and mileage should never be used in the same sentance but...its my dd
Old Dec 15, 2012 | 08:16 AM
  #83
badassracing's Avatar
I know a guy running the v3 with stock heads and he seems to like it. He is running stock rockers with no problems. Seems to be very streetable. He's never had it on a dyno but runs consistant 12.0s with a m6 and full weight. I also know a guy that had a cam similar to the v2 (cant remember the exact specs) with patriot 243 heads and head ran consistant 11.7s with a best in the 11.3s. that car was also full weight m6. Both of these cars were running stock rears with nitto drag radials.
Old Dec 15, 2012 | 09:31 AM
  #84
I would settle for ll.3, and time would be lower with v3 and 243s....I was going to wait till I got back from Afghanistan and get a stroker kit and a 80 mil turbo.....but I might just spend 2k on some trick flows and call it good
Old Dec 15, 2012 | 09:33 AM
  #85
Dickie-311's Avatar
Originally Posted by camaroboiss
What gears are u running....
It's my dd...I've heard people on ls1 tech getting better mileage...but still high 20s on 3.42...
Does your power curve go up all the way to 73 or does it flatten out before it.
my cars got 4:30 gears with an overdrive transmission ,
on the dyno my motor was still making power at 7300 but i shut it down , being a stock shortblock i didnt wanna break it ..
Old Dec 15, 2012 | 09:37 AM
  #86
Nice....I would shift at 6-65 but it would be nice to know its there if I need it
Old Dec 15, 2012 | 10:14 AM
  #87
HCI2000SS's Avatar
Then slap on a used nitrous kit for like $500, and you'll have some cheap extra insurance just in case lol
Old Dec 15, 2012 | 12:49 PM
  #88
I'm scared to do that...my little brother told me one shot is the equivalent of adding 30,000 miles to your engine..and all the horror stories I hear about nitrous gone wrong turns me away from it.
Old Dec 15, 2012 | 12:55 PM
  #89
HCI2000SS's Avatar
Dude I promise you that is not the case! Set up right, and it's no different than a running a blower or turbo. Listen I ran a 100 shot in my Mustang for over 4 years, and not one single issue! Plus I was pushing over 400 rwhp on that 04 gt which was "theoretically" pushing the stock internals to the limit. It's all about the tune, setup, etc...
Old Dec 15, 2012 | 01:06 PM
  #90
99Bluz28's Avatar
IMO, you can't go wrong with a good set of heads, regardless of the direction you take your build!
Old Dec 15, 2012 | 04:21 PM
  #91
You can totally waste money thought....like buying high compression heads then going to a turbo setup....you'll have to switch
Old Dec 15, 2012 | 04:22 PM
  #92
Man,that sounds like it would be fun....maybe if I rode in one I would change my mind
Old Dec 15, 2012 | 10:08 PM
  #93
Bramlok's Avatar
I went from a 228R to a V3. The V3 pulls hard everywhere all the way screaming to redline. But I'm running ported TSP heads and a FAST 102.
Old Dec 15, 2012 | 10:29 PM
  #94
99Bluz28's Avatar
If you're seriously planing a future turbo build then don't get them milled, just run thinner head gaskets for now.
Old Dec 16, 2012 | 01:14 AM
  #95
But on a all motor what's milling worth whp wise
Old Dec 16, 2012 | 01:21 AM
  #96
Off topic but if u guys want to see how my car does now check out my YouTube acct,username:sradman750
I just ordered a tick master cylinder, Ittl be in Monday and hopefully eliminate the dead ads pedal....hd pressure plate really messes up your shifting
