5.3 heads
Old Dec 15, 2012 | 05:40 PM
carbed86fox's Avatar
Default 5.3 heads
is it really that big of a difference to change the valves in 5.3 heads to ls1 valves?
Old Dec 15, 2012 | 05:57 PM
KCS's Avatar
KCS
Moderator
It can be. With a good valve job and minimal blending, they will outflow 243/799 heads, produce a higher compression ratio, and cost just as much, if not less than the 243/799 heads.
Old Dec 16, 2012 | 01:46 AM
chrisfrost's Avatar
The 5.3L heads have the same valve seats as the 241's and the 243's so in My opinion You can do better by leaving the 1.89's and the 1.55's and just cutting the inner diameter of the seats a little larger . They can be cut to the same as a 1.94 leaving the 1.89's in without as much shrouding by the valve or the side of the combustion chamber . And the exhaust 1's can be cut to the same as a 1.6 . So think about it and take You're pick .
Old Dec 16, 2012 | 08:34 AM
KCS's Avatar
KCS
Moderator
Do what?
Old Dec 16, 2012 | 10:07 AM
how much would it cost at the machine shop to get the valve seats cut to put the ls1 valves in?
Old Dec 16, 2012 | 10:42 AM
wildcamaro's Avatar
Probably the same price or more compared to buying a set of ls1 heads for $100, but the you would have to mill those to get the compression back up, so pick your poison...
Old Dec 16, 2012 | 10:48 AM
KCS's Avatar
KCS
Moderator
It depends on the shop, but $200 is pretty much standard.
Old Dec 16, 2012 | 10:50 AM
KCS's Avatar
KCS
Moderator
Exactly, and then you're limited by piston to valve clearance.
Old Dec 16, 2012 | 10:55 AM
AGearHead4Life's Avatar
I'd like to know this as well. I wish somebody had a flow sheet of difference.
I just did this to my 5.3 but didnt have $ for a flow test. I am about to see dyno differences soon, but it wont be a measurement of just the larger valves because i also milled .030" and home ported them.
Old Dec 16, 2012 | 11:09 AM
i have some ported ls1 heads on my car right now but i would also like to see how big of a differnce the bigger valves and more compresiion will do let me know when you get those dyno numbers back
Old Dec 16, 2012 | 11:16 AM
sidearmbandit's Avatar
Here is what my 2.02/1.60 5.3's did on the flow bench. Can't tell you how they ran because they've never been installed. Project is getting canceled and they are actually for sale in the classifieds.
Old Dec 16, 2012 | 11:49 AM
Daumn! Looks like I need to invest in some 202's!
Got a for sale link?
Old Dec 16, 2012 | 11:55 AM
wildcamaro's Avatar
Hey sidearm where those 5.3 heads ported as well? It seems hard to believe that just swapping valves netted that much of an improvement!
Old Dec 16, 2012 | 12:02 PM
I've pretty sure they were ported. Not only from the numbers, but look on those Combustion chambers.
Old Dec 16, 2012 | 12:27 PM
Yeah they were ported/polished as well. I know it won't be a direct comparison to his question but they aren't going to flow that well with the smaller valves either.
Sale link:
https://ls1tech.com/forums/parts-cla...s-goodies.html
Old Dec 16, 2012 | 07:48 PM
i already have some ported ls1 heads so i might just check my ptv clearance and see how much i could mill them
Old Dec 19, 2012 | 09:49 AM
omc8's Avatar
Originally Posted by KCS
Do what?
I understand ,I have considered doing 1.94 Intake and 1.59 Exhaust on 5.3s and get them ported. The cheapest route would be just do the the Intake side and swap your LS1 2" over , and run with the 1.55 .The 5.3 already has 1.55 on the exhaust side. Get a performance VJ and some light hand port and call it a day.
Old Jan 25, 2013 | 11:14 PM
That is the route I took... Stock LS1 2" valves and a home port job and then milled .030".
Old Feb 12, 2013 | 02:47 PM
To answer the orignal question, I dont think you'd see much if any gain from just the 5.3 to LS1 intake valve swap. They flow the same as they are in stock form. But like others have said with a port job and a cam that needs to breath you will see a difference.
I finally got my 2" valve, .030" mill and home port 5.3 with LS6 cam through a 80e dyno'd. 329 rwhp and 334 tq.
Now itching for a larger cam and stall...
