Pushrod length and lifter preload
Old Dec 18, 2012 | 08:08 PM
88Fbody6L's Avatar
Default Pushrod length and lifter preload
I have an LQ9 with 243 heads, stock MLS gaskets, LS7 lifters and MS3 camshaft. My question is this: with the stock pushrods I measure .050 lifter preload using the dial indicator method. I read somewhere that stock pushrods were 7.380 so I was banking on using 7.400 to get me to roughly .070 of preload. However, tonight I measured my stock rods and they are 7.400. Will this be enough preload or should I step up to 7.425 to get around .075?
Old Dec 18, 2012 | 09:43 PM
JakeFusion's Avatar
Super Hulk Smash
Generally, with the smaller base circle of the cams ground on Comp billet cores, you need more pushrod to get the same preload. 7.425" is accepted as optimal for a stock engine with a Comp billet core cam.
Old Dec 18, 2012 | 10:00 PM
outkast6991's Avatar
I'm running .035 on a similar setup with no noise at all
Old Dec 18, 2012 | 10:07 PM
Ferocity02's Avatar
How did you measure the pushrods? There is actual length (end-to-end) which is easy to measure, and gauge length which is what Comp uses. Just something to keep in mind. I don't know if 7.380 is the actual or gauge length.
Old Dec 18, 2012 | 10:28 PM
88Fbody6L's Avatar
I measured using theoretical length. Can anyone confirm that the 7.400 is in fact longer than the stock rods?
Old Dec 18, 2012 | 11:28 PM
Ferocity02's Avatar
Theoretical length is the length of the pushrod without the hole drilled through it, I doubt you measured this. Drilling the hole through the pushrod puts a "flat surface" on the ends effectively shortening the pushrod slightly. If you measured end-to-end, then you measured actual length.
Old Dec 19, 2012 | 05:10 AM
88Fbody6L's Avatar
Ok then. Actual length is what I measured
Old Dec 20, 2012 | 07:03 AM
vettenuts's Avatar
I measured stock on a LS1, they were 7.385" gauge length. The 7.400" will be gauge length of bought from Comp or several other vendors, which all actually are made by Trend. I would contact Trend directly and get the pushrods. They also have very good technical support who I worked with when I did my double taper pushrods. I would also consider a stiffer 11/32" OD pushrod from Manton.
Old Dec 20, 2012 | 07:37 AM
gagliano7's Avatar
On my 2004 5.3 the 7.4's were longer than my stock pushrods.
Old Dec 20, 2012 | 01:42 PM
88Fbody6L's Avatar
Thanks for the input, guys! I will go with the 7.4s then and that should give me .065-.070 preload.
Old Dec 20, 2012 | 02:19 PM
A.R. Shale Targa's Avatar
If you haven't bolted the heads on yet....a 0.025 mill would help your preload
as well as add 1/2 point of compression...helpful if running NA
Old Dec 31, 2012 | 04:22 PM
88Fbody6L's Avatar
Just thought I would update this......My stock pushrods measure 7.397 and my new 7.400 rods measure...well...7.400. So, all this gauge length, theoretical, actual stuff didnt mean a thing. Measure them tip to tip.
