.125" pre-load on ls7 lifters
Old Dec 23, 2012 | 05:59 AM
td1168's Avatar
Default .125" pre-load on ls7 lifters
What affect will running .125" preload have on my valve train? I measured with a pr length checker and thats what I'll end up with using my 7.400 pushrods. Also my lengths vary so .125 is the heaviest preload. Some lifters will end up at .100"
Old Dec 23, 2012 | 10:04 AM
badazz81z28's Avatar
Too much imho
Old Dec 23, 2012 | 10:21 AM
td1168's Avatar
Thanks for the reply badazz81z28. I really haven't got much other advice about preload. Jake at TSP told me between .040" & .080" but I've seen guys running as much as .100." I'm gonna go ahead and order 7.350 pr's to put me where Jake recommended.
89gmcs15's Avatar
i ran .080 with no noises with my ls7 lifters
Old Dec 23, 2012 | 10:23 AM
td1168's Avatar
What kind of cam are you running?
Old Dec 23, 2012 | 10:43 AM
A.R. Shale Targa's Avatar
THIS ^^^^^^^^^^^^LS7s typically work with less preload than old LS1s
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I'm running one full turn from zero lash to 22ftlbs and no issues here.
Old Dec 23, 2012 | 12:11 PM
Sales@Tick's Avatar
.050-.060 is what we set them up with here at the shop, but we've run as much as .080 with no issues.
Old Dec 23, 2012 | 02:04 PM
Ferocity02's Avatar
I've run up to 0.100" without issues, but went with 7.325" pushrods to average 0.075". 0.125" is too much IMO.
Old Dec 23, 2012 | 06:20 PM
RezinTexas's Avatar
0.045" here, quiet as a mouse
Old Dec 24, 2012 | 08:17 AM
studderin's Avatar
thats alot, I wouldn't run that for a long time. Did you check how much preload you have until the plunger bottoms out? You will crack the lifter body, or have plunger, and wheel problems if it runs like that.
