Hole in block!!
Old Dec 26, 2012 | 09:38 AM
jays78's Avatar
Default Hole in block!!
First off I came over from the corvette forum, I am planning on putting a ls engine in my 78 corvette. Ran into a major setback and need some good advice.
Try to keep my story short.
I won at a government auction a wrecked 2002 z28 4l60 trans, wasn't able to start or inspect before bidding. Well I got it in my workshop checked the oil, radiator was shot from wreck, I wanted to here it run before I removed it. Started it up it shaked and banged, Well now there is a hole in the block, don't know if it was already there or if it was my fault, I haven't got it out yet, as soon as I do I will tear it down.
At this point its mine and I want to move forward.
All I wanted was a bone stock ls1 with auto trans, for a daily driver old vette, so now I am looking to repair what I got or just scrap the whole deal.
I have built engines before, small block and big block chevys but didnt really want to go thru the expense of machine shops parts packages and so on. At this point I will if it will get me where I want with the least amount of cash.
So what do you think?
I noticed summit has block 1500, or I also noticed a LQ4 6.0 long block for 1700 but will my parts work with that? heads, intake, accessories,etc?
Old Dec 26, 2012 | 10:21 AM
boostit5.3's Avatar
the 6.0 will work with everything and they can be had for under $1000. i have a 98 z28 that i put a 1999 5.3 truck motor in and everything works but 1 bolt hole for the alternator. but ive been running with the other 3 and it hasnt loosened up i have been daily driving the car. you could also get a 5.3 block for cheap and bore it out and use all your ls1 internals in it and make a iron ls1. but IMO i would find a 6.0!
Old Dec 26, 2012 | 12:08 PM
jays78's Avatar
If it will work, I may just do that. The torque from the 6.0 would be nice.
So everything from the oil pan to the valve covers will work on the 6.0 block?
The long block complete is only 1700 all new at summit, I live 5 miles from so no shipping, I can't rebuild one for that!
Old Dec 26, 2012 | 12:34 PM
96capricemgr's Avatar
I wouldn't buy a cheap "rebuilt" longblock, stock stuff is pretty good and cheap aftermarket stuff is usually a step backwards.
Can you give us a link to the $1700 longblock?
If you are accustomed to the old stuff I don't think you realize what sort of power you can get from the LS engines, a 5.3l with a cam would easily make what the older BBC Vettes did. The torque from a 6.0l will be hard to harness on the street unless you have put work into the chassis. Not saying it is a bad idea, just saying folks like to talk up torque when looking at larger engines and frankly these days it is really really easy to have more than you can use on the street.
Old Dec 26, 2012 | 01:26 PM
jays78's Avatar
http://www.summitracing.com/parts/hp...make/chevrolet
There is the link to summit.
I have read a lot about these ls1 engines and am looking forward to the swap. I drive one everyday in my 2006 silverado, its a 5.3 , now I am not looking to go street racing, but don't want to be out done by no kid in his rice burner either, being able to light up the tires on command and still get 25 miles to the gallon with the a/c on, that's what I am looking for.
Old Dec 26, 2012 | 01:44 PM
boostit5.3's Avatar
yep i have a f body oil pan on my truck block right now and the valve covers.
Old Dec 26, 2012 | 01:52 PM
jays78's Avatar
Sorry what I meant was everything in between the oil pan and the valve covers.
Old Dec 26, 2012 | 02:12 PM
parks450's Avatar
Yes, everything is basically inter-changeable. About 99% of it is, cam heads crank etc. pistons are not for obvious reasons.
Old Dec 26, 2012 | 02:24 PM
Tainted's Avatar
6.0 or bust, cant say no to more CI, and more heads choices
Old Dec 26, 2012 | 02:30 PM
The 5.3l moves a Silverado around adequately and stop and think about how much modern trucks weigh compared to that Vette.
The link is a shortblock, still I wouldn't buy a shortblock that cheap.
Old Dec 26, 2012 | 02:51 PM
jays78's Avatar
The shortblock is all I need, freshen up the heads they have 90k miles on them. Get the pcm programmed, get a wiring harness, and fuel system. What else am I missing?
Old Dec 26, 2012 | 02:57 PM
Tainted's Avatar
Check out thompson motorsports ------------------->
Old Dec 26, 2012 | 05:18 PM
jays78's Avatar
I forgot to mention, I am parting out the camaro. It got smashed in the front and back, air bags popped, let me know if there is anything you might need.
Old Dec 26, 2012 | 10:01 PM
lizeec's Avatar
Like stated above check out Thompson, although you will have freight to add to your purchase. If a vendor sells that short block through Summit you should be ok, Summit didn't get to where they are at by not standing behind what they sell and giving excellent service. Plus if they are close by that is a plus.
Old Dec 27, 2012 | 08:49 AM
jays78's Avatar
I would have to agree, I have purchased a lot from summit and have always had excellent customer service. There return policy is better than Walmart! Lol
Old Dec 27, 2012 | 11:19 AM
wildcamaro's Avatar
Yea transfer you ls1 top end to the lq4 and you should have decent compression, at least 10:1, and 1700 ain't bad at all for a shortblock...
Old Dec 27, 2012 | 12:09 PM
thompson's Avatar
Make sure and call us before you buy anything, Our 370CI short blocks will start at $1999 and is 10 times the block on summit for $1699. We used to sell the same motor for $1599 and discontinued it for our TMS 370 to include the upgraded pistons, rings, bearings and over sized cylinders to allow for less valve shrouding. We can also get you in our most popular motor the Forged piston and rod 370 for as little as $2799. You cant beat that ANYWHERE.
Old Dec 27, 2012 | 02:42 PM
jays78's Avatar
I was looking at the aluminum 5.7 on your web site, I would probably go with that, what would the shipping cost be to Atlanta? I can pick up from shipper.
Any discounts for us LS1TECH.com Fans!!
Old Dec 27, 2012 | 05:18 PM
thompson's Avatar
PM sent.
Old Jan 6, 2013 | 06:21 PM
jays78's Avatar
Update on the carnage!
Its officially my fault, when I took off the intake it was full of water.
It seems that on the trailer ride home I remember it poured down rain, the air box was broken and the throttle body was exposed. The hood was like a scoop from the wreck, it funneled water into it. I should have known better.
So meantime I will be parting out the rest of the camaro, need the money to get me that new short block from Thompson
Car has good doors, rearend, tires and wheels, I was about to list them on craigslist. My question is what are they worth? And is there any other places to sell? I sell on ebay but some of these larger parts I need to sell local.
Thanks for your input.
